I'd like to see some proper floor replacement pictures. Some people over lap and weld, others butt to butt . Which is proper way for " Truely restored trucks " Should the joint not be visible after welding , grinding.
Would appreciate your input.
Jock, Powder blasting shop, Alabama Last edited by jacquesdean; 04-02-2003 at 12:27 AM. |
I am partial to the butt weld, since there are no cavities that can rust, and it can be ground perfectly smooth where the repair is really difficult to see.
69 SWB LT1/4L60E www.classicplace.com |
![]() Join Date: Mar 2000
Here's one of a butt joint.
Saskatoon, Saskatchewan Canada |
Floor all done
floor repairs
Thanks Stingray,
appreciate you taking the time to send pics, greatly appreciated. ![]()
Jock, Powder blasting shop, Alabama |
Nice work stingRay, what year truck is that?
I wish mine looked that good. I'm not a welder, so I paid good money to have it done. Nobody ever does what you want done as well as you want it done. Nice work!!
Silence is golden, duct tape is silver. - Scott |
Here are a couple pics of when I did mine. I use the butt-joining method, and I don't think I would do it the other way. Partly because of the way it would look, but also because I know that it would be so much easier and I would think that I just didn't have the ability to do the butt joints.(not meant to be a rag on anyone who uses the layover method) I am not a very good welder, and these pictures look better than real, but it gives you an idea.
Low68
Build Thread |
Here is a picture of what it looked like on the bottom of the cab. I had my cab off(obviously) so it made it a whole lot easier to do. Good luck.
Low68
Build Thread |
Nice work, did you dip the cab?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
heres the non-proper way. you compair this cab is total junk (unfixible rust all over) so i just wanted to make it driveable till i jet a new one later any ways heres a pic.
ps. it was PITA LOL -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
I prefer a butt weld, A lap joint could allow moisture to get under
it and rust out again.
"Negative people always seem to have a problem for every solution" |
#13 |
Blue Beard, is that question for me? If so, no. I had it sandblasted.
Hey Eddie H., is what kind of welder is that? I think I have used one of those in my welding class. The one I used was stinking slow. Is that? Thanks Low68
Build Thread |
#14 |
I'm using a Henrob 2000 Torch in that picture. I really like it. It's mainly designed for aircraft metal work, but you can weld nearly anything with it: Steel, Stainless steel, aluminum, cast iron, or even thin sheet metal.
#15 |
Here's a picture of the floor repair from a different angle.
#16 |
eddie:
you wouldn't happen to have a website for Henrob would you?
#17 |
See if this link works:
http://www.cut-like-plasma.com/
#18 |
![]() Join Date: Feb 2003
rod
Is that 1/16" copper coated mild steel rod you're using with that Henrob outfit ? It doesn't look like you're using any kind of heat sink to minimize distortion. I used to use a "O" oxy/acet tip with the pressure set very low (just high enough to prevent popping) and still used to get some distortion. Does this unit eliminate that ????......Thanks.....Zoomy
#19 |
I'm using 3/16 inch mild steel rod in that pic, but 1/16 works better for thin sheet metal.
The Henrob operates at only 4 psi on the gas and 02 so you get a soft concentrated flame that is hotter and much more controllable than with a conventional type of torch. You can still get some distortion if you stay in one place too long, but with a little practice, you can make some really clean welds. I've had good results with it so far. Ck out their website for some online demos and more info: http://www.cut-like-plasma.com/
"Negative people always seem to have a problem for every solution" Last edited by Eddie H.; 04-04-2003 at 11:22 PM. |
