Old 06-21-2011, 10:06 AM   #1
veinbar
veinbar's Avatar
Replacing Driver Side Front Quarter Panel.
Slight fender bender. Is there a diagram or website that can help me remove and replace a panel step by step? I'm sure I could just dive in and start removing bolts, but I want to do this right. Also, any tips on aligning the panel as well will be appreciated.
veinbar is offline   Reply With Quote
Old 06-21-2011, 10:36 AM   #2
Jonboy
Slots go on anything!
Re: Replacing Driver Side Front Quarter Panel.
Removing the fender isn't too bad. There are 4 bolts on the inside at the radiator support, 2 bolts holding the grille filler to the fender, and 7 bolts holding the inner fender to the outer in the wheelhouse. These should all have a 1/2" head. There are 1 or 2 inside the door jamb, 1 at the cowl, and 1 under the bottom, from the inside at the rear wheel. These may or may not have shims, so keep track of the shims if there are any. You will need to remove the hood as well.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-21-2011, 06:27 PM   #3
bmchevy1979
bmchevy1979's Avatar
Here you go http://73-87.com/7387garage/exterior...stallation.htm
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
