06-21-2011, 03:59 PM | #1 |
Normal oil pressure reading on a BBC Dually?
So just have a quick question. What is the normal operating range for the oil pressure on a 454 bbc? This engine is in a 1987 GMC DRW. the engine is supposed to be bored .030 over and has an Edelbrock carb with Edelbrock peformer 2.0 intake. Also what is the normal operating temp? right now it seems to run around 210 or so and when stopped these last few days in 90 defgree weather it gets up to about 215 or 220 but i get no boilover at all. Is this normal?
06-21-2011, 04:12 PM | #2 |
Re: Normal oil pressure reading on a BBC Dually?
humm that seems kinda high. i get around 50 psi on oil and 190 on temp
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
06-21-2011, 04:29 PM | #3 |
I get around 25 at idle and at start up around 75. I wonder if I need to burp my cooling system or possibly get a cooler thermostat
06-21-2011, 04:50 PM | #4 |
I would typically have about 40psi @ start-up & 50-60psi @ speed. For temp it would be between 180-195°F.
I've been struggling w/cooling issues since March though. It appears I had a head gasket seeping into the engine on the exhaust side so the water level would drop w/o external indicators. Recently (Friday night), it would appear to have breached into the crank-case side as my oil pressure was diluted to near zero & the motor siezed. Working on swapping it out as I write this.... I would make sure your radiator is fresh as well as replace your hoses & t-stat.
06-21-2011, 05:21 PM | #5 |
In my 83 C20 BB 454 I normally show 40-50 psi oil pressure, pretty much constant in that range. Temperature is 180-190 degrees - never goes over 200 degrees, even in 115 degree ambient desert heat. I just have a Goodwrench rebuilt 454 with slight bore over from GM (forget how much) and stock Qjet - totally stock setup with Ready Rad thicker 3 core radiator (about the thickness of a 4 core) with stock engine oil cooler. I have had more cooling issues with my small block 350 than the two 454 squares I have owned. It has a factory 7 quart oil pan. I did have a slight external leak at the front of the intake manifold but some stop leak tablets seems to have stopped that, and it never caused overheating, just a little coolant loss.
06-21-2011, 07:46 PM | #6 |
My 85 runs 30 at idle 45 at highways but with the overdrive gear i don't see very high rpm's if i dog it i get 60+. Mine never gets above 160 tempature wise
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e Last edited by Goldfinger; 06-21-2011 at 07:47 PM. |
06-22-2011, 12:04 AM | #7 |
My '77 in the sig is 50 plus pounds on start up, 25 at idle hot. It runs 180 with a 180 thermostat and 195 with a 195 thermostat. It never waivers much from there.
06-22-2011, 09:07 AM | #8 |
In my 89, it came with a 210 thermostat. she would sit at 210 all day long on the highway, then in heavy traffic, it would creep to 220. it would smell hot all the time, but it never gave me any issues. that being said, I didnt like that one bit so i swapped in a 180 thermostat, and now she runs a 180 all the time and never gets above 190 no matter what im doin to it. as far as oil pressure, i run 50psi or so at start up. hot idle is right around 15 psi, and hot driving at 2100 rpm on the highway is about 22 psi
1989 V3500 nv4500/np205 255-85-16 BFG Mud Terrains, 4inch skyjacker kit, 2 inch body lift. "Yea, it was a fuel supply problem. A rod came through the block and cut the fuel line." |
