06-21-2011, 08:18 PM | #1 |
From Mine to Hers Build
Well I guess I need to go ahead and start the build thread on this truck. Its a 68' C10 swb. 70 front suspension already installed. This is going to be a full frame off resto on this one. Kinda late on starting the thread for the build due to the fact that alot of stuff has been done, but there is still plenty of work to be done. So far I have sanded and primed and painted the entire frame. Some small repairs but nothing major. Paint entire frame and suspension with summit chassis paint. All new bushings, ball joints, and tie rod ends. 3" drop springs in the front and 5" drop springs in the rear.
Currently I'm trying to knip the bodywork in the butt. Going to have the roof welded up and finished this week(had to cut the old off and replace with a nice hand me down.) Other then that I will start it off with this and just continue on as I go. Kinda got a kick in the butt from my buddy to get this started, BACKYARD88. So thanks for that Mike! Anywho I will post some photos up here soon! |
06-21-2011, 08:31 PM | #2 |
Re: From Mine to Hers Build
Basic pics.
06-21-2011, 08:33 PM | #3 |
Afew more
06-22-2011, 09:33 PM | #4 |
Okay color change..... Refer to page 3 for the update!!!! Ahhhhh the closer it gets to paint the more I want to change the color!
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 Last edited by late68; 02-22-2012 at 10:44 PM. |
06-22-2011, 10:31 PM | #6 |
Working on it.... Yea I'm around 45 and louetta.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
06-23-2011, 11:18 PM | #7 |
Looking good in Spring.....from down south in the Pearland area.
06-23-2011, 11:47 PM | #8 |
Thanks! Yea Pearlands not to far.
06-27-2011, 03:39 PM | #9 |
On the fast track to nowhere..
Bout time
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-27-2011, 07:59 PM | #10 |
Yea yea, i know!!!! Pics to come of the roof being done...
06-27-2011, 11:02 PM | #11 | |
Oh and this is going to be a 6.0 build. Gonna have a 6.0 out of a silverado.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 Last edited by late68; 07-02-2011 at 03:06 PM. Reason: Wrong engien size |
07-02-2011, 02:34 PM | #12 |
Well officially picked up my motor today. The seller "said" that it was a 5.3 But low and behold after I picked it up it's a 6.0. Hellz yes for me, couldnt have gotten luckier! Here are some pics...
07-03-2011, 04:16 PM | #13 |
Got the engine torn down...... ouch!
looks like I'm in need for some pistons. So here's my question. Should I got back stock or should I spunk it up a little. Planningon putting a cam in it and some head work. So not to sure. Any ideas????????
07-09-2011, 06:50 PM | #14 |
Well so a small update. Got the bad piston out. Checked out the block, looks like it's going to need some work done. Has some pretty good gouges. (enough to catch your nail) So now I need to find out if it has to be bored to get fixed and if so what kind of pistons i have to buy... Ughhh what a PITA. But gotta do it. Still in process with the roof getting welded up. Will have some pics up as soon as its completed.
07-09-2011, 06:56 PM | #15 |
Pics
07-09-2011, 08:02 PM | #16 |
I'm in the TMC (med center). You prob already are but be sure you check those heads over closely, I cracked one when my old 427 did that to the piston. Good luck and the 6.0 will be kick ass in this truck!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
07-09-2011, 09:06 PM | #17 |
Yea the heads will be going to the machine shop. Hopefully they are okay. Looks like just some minor cosmetic stuff but that can turn around in a second.
07-14-2011, 04:09 PM | #18 |
Well not a whole lot going on this week. Got a 5.3 motor that I'm going to take the heads off of for my 6.0.... The heads on the 6.0 have some cracks in them and if I go ahead and run the 5.3 heads it will be a little more compression and more flow. So that should work out pretty good. Just kinda at a slow pace right now.
07-19-2011, 12:55 PM | #19 | |
Still plays with trucks
If you want to run a turbo you don't want to bump the compression any so I would try to get the 6.0 heads repaired rather than put the 5.3 heads onto it. I would take all the accessories off the 5.3 that you need for your engine and sell off the 5.3 long block to fund the repair work on the 6.0 stuff. Go with some forged pistons and ARP rod bolts & main bolts when you put the short block back together along with dropping in a turbo friendly and more aggressive cam.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-19-2011, 08:03 PM | #20 | |
http://houston.craigslist.org/pts/2462747681.html I know the bore is bigger, but would the pistons work for that application.
07-20-2011, 10:30 AM | #21 | |
07-21-2011, 03:07 PM | #22 |
subscribed I like the color and the LS
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
07-21-2011, 05:52 PM | #23 |
Going to pick up a 5.3 that i bought from BACKYARD88 this weekend, so hopefully I can get some progress rolling on this baby.
Thanks Doug.
08-15-2011, 10:07 PM | #24 |
So I guess i have a bit of an update. Got all of my engine parts together. 6.0 block and lower end and 5.3 heads all of the the machine shop to be fresh'nd up. All new bearings, seals, and rings. Not sure on cam choice yet but thats in the making. As for the truck. Roof has been welded on and paint process has begun.....I'm sure a few weeks to come on that though....
08-22-2011, 10:25 AM | #25 |
Well here's another "small" update in this longggggggg build. Seems to be going slow for me! Got my hood finished up (and primed) just dont have a photo of that. Fender is finished except for the fact that i now have to shave the side markers on this thing... And lets not forget my kids new toy that I now have to add to the list of things to do!!! haha
