06-21-2011, 09:08 PM | #1 |
Active Member
Water pump rebuild
Where do you get a water pump rebuilt. I want the same pump back so
I can stay origonal. Or where can you find parts to rebuild your own...I have a press for the project.
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
06-21-2011, 09:17 PM | #2 |
Re: Water pump rebuild
I didn't know people still rebuilt them! It's been 20 years since the last one I rebuilt, but I got the parts from napa. Couldn't tell you if they still carry them. Good luck!
Posted via Mobile Device |
06-21-2011, 09:45 PM | #3 |
Long Island Corvette Supply sells a few kits. Check section 21 in their catalog.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
06-21-2011, 09:54 PM | #4 |
Moderator
I have seen water pump rebuild kits on ebay.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-22-2011, 10:11 AM | #5 |
1969 Custom 30 wrecker
Easy to do if you have a shop press. (or know someone that has one)
Instructions can easily be found on the net. I did one a few years ago for my 66 Impala and had no troubles.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-22-2011, 11:01 AM | #6 |
454 MAKES IT ROAR
Have a look here...
http://user.cavenet.com/tmac1/chevrolet.html
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
06-22-2011, 11:09 AM | #7 |
I had one done at a CarQuest store. It was for a '60 Cadillac. They couldn't find one, so they had my original rebuilt. I think it was like $50 or something and took about a week. Probably CarQuest or NAPA can get it done for you.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-22-2011, 11:40 AM | #8 |
Old Skool Club
From personal experience....I bought a rebuild that leaked when I fired it up. The cover bolts on the backside weren't tightened properly. I swore off rebuilds, after that.
Now, with the economy as it is...rebuilds don't look too bad. Just tighten all the bolts, first.....before installation.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-22-2011, 12:30 PM | #9 |
i've found alot of rebuilders for all sorts of different stuff in hemmings motor news// have always been able to find people somewhat local to my locations over the years
06-24-2011, 05:59 PM | #10 |
Active Member
Well thanks folks for all the reponse. I found a kit on Ebay and am waiting
for it to arrive. The 7/16 bolts on the rear plate should be about 15 to 20 inch pounds and will use blue sealant and hope for the best...Will post a thread as to the results..James
06-24-2011, 08:04 PM | #11 |
454 MAKES IT ROAR
You will need the gasket for the back, fiting the cover without it & just using sealant lets it sit to close to the impeller and it rubs on the inside....happened to me anyway.
06-24-2011, 08:29 PM | #12 |
Active Member
Thanks for the tip, the gasket comes in the kit. So which end comes apart
first? Do you use a standard puller for the fan hub? I couldn't find a lot of info on the net for this job. I have never done one before. Guess I should document the position of the hub and impeller on the shaft to get them pressed back on in the same position. LOL
06-24-2011, 10:02 PM | #13 |
454 MAKES IT ROAR
I know there is nothing out there for the DIY WP rebuild, I gave up on the idea I was already rebuilding my trans & my carb, so I was happy to just check it for wear and it seemed fine, then striped the old paint off it, installed new gasket & a repaint....kinda hoping it's a case of "if it aint broke"
We'll see when it gets reinstalled. Good luck with yours mate.
06-27-2011, 09:08 PM | #14 |
Active Member
Yeah I was gunna do that to but I have 3 or 4 of the short pumps and thought I would give it a go eah! Still waiting for the parts. James
