Old 06-22-2011, 12:34 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
TBI to LS?
What all is involve with swapping from a TBI 350 to a 5.3 LS? Excluding motor mounts and trans adapter(s). I can get a 5.3 shipped for $400 with less than 120K miles on it, which is cheaper than upgrading the TBI 350 to try and achieve LS engine MPG. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-22-2011, 12:48 AM   #2
CamaroChris
Re: TBI to LS?
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 06-22-2011, 12:53 AM   #3
thirdstreettito
Resident of Here
Re: TBI to LS?
Where's the TBI swap info in there?
~Bradley~
Miss having a truck
Old 06-22-2011, 03:14 AM   #4
CamaroChris
Re: TBI to LS?
Read through it, Read build threads, try the search button. There is so much info in this forum. you just have to spend some time researching.
I LIKE TRUCKS
Old 06-22-2011, 03:36 AM   #5
CamaroChris
Re: TBI to LS?
The only thing that I would think you would even keep from the tbi set up would be the fuel pump. the Ls motors pretty much hold their own. stand alone 4-10 wire hook up. read through glocks build
I LIKE TRUCKS
Old 06-22-2011, 08:51 AM   #6
thirdstreettito
Resident of Here
Re: TBI to LS?
I have searched. I found a bunch, but I dont know how to sift through all the technical stuff to get to the lamens terms of stuff. Like, how do I deal with the ECU? How do I hook up the ignition? What CAN I use from the TBI, what CANT I use from the TBI? Etc Etc
~Bradley~
Miss having a truck
Old 06-22-2011, 10:10 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: TBI to LS?
For the ECU;
You need to have VATS, EGR, and rear 02 sensors tuned out, this will allow the engine to function normally without all that stuff (which 98% of us have removed). At that point, any additional equipment like cam or injectors can be compensated for so the vehicles can start and maintain a decent idle. You also calibrate for rear tire size and rear end ratio in the tune. This is usually done through something like HP tuners. Mail order tunes can do this for you, but NOTHING replaces a true tuning session with a pro.
Ignition: if you have a harness made for you, ignition will be just a couple of wires to hook up to your ignition switch and a power source. Very easy.
You'll need a new fuel pump that can supply to correct pressure, and with that you will need to replace any low pressure fuel line with Fuel Injection safe rubber or braided line. You will either need a vette style filter-reg, or a return system depending on which motor you are using.
You really won't be keeping much of the tbi. The wiring for the ls engine is mostly self contained in the harness, and there is a minimal # (IIR less than 10-12) to hook pretty much everything up. None of the SBC components will be kept, nor will most of the fuel system. You will want to keep the sbc mounts to bolt your adapter plates to for the ls style engines.
Not really sure what you'd want to keep off the TBI anyway.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-23-2011, 12:52 AM   #8
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: TBI to LS?
You have to read Glock's thread from start to finish. It pretty much tells you everything you will need and where to buy it if you can't locally. His was a 5.3 as well.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
