Old 06-22-2011, 05:00 AM   #1
kanuck
what motor mounts for 454?
Just picked up a 454 that was pulled from an 80's suburban.
I only have the steel mounts that are bolted on the motor, but am wondering what I need to mount it to my 1977 frame.
I have several 73-80 and 81-87 half and 3/4 ton trucks, but they all came with either a 6 cylinder or small block motor.
Do I need to get something different for the big block to install it?
Thanks for any info.....
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 06-22-2011, 05:02 AM   #2
78maliburat
Re: what motor mounts for 454?
all bottom mounts are the same
78maliburat is offline   Reply With Quote
Old 06-22-2011, 06:03 PM   #3
kanuck
So your saying I got bonus since the part on the motor was the only different piece?
The frame mount for the small block should work?
How about the rubber isolator piece?
Old 06-22-2011, 07:15 PM   #4
baclay9
All the mounts are the same. I just did a 350 to 454 swap on mine.
baclay9 is offline   Reply With Quote
