Old 06-22-2011, 09:12 AM   #1
Buckeye Puller
Buckeye Puller's Avatar
70 Chevy....Project rebuild
This is my 70 chevy. I got this truck when I was 16 for $250 from a friend of mine. It was a 6 cylinder and 3 speed on the tree. My father and I took a summer off from drag racing to build this truck. We put a small block in it, changed it to disc breaks all the way around, put air ride on it, and many other body mods. He done all the paint work on it. It has been almost 11 years since it was built so its time for a face lift. I always wanted it to be a short bed, so I found a good 67 short box for it. Now the project rebuild will start.
Buckeye Puller is offline   Reply With Quote
Old 06-23-2011, 01:42 AM   #2
michaelofpetaluma
michaelofpetaluma's Avatar
Re: 70 Chevy....Project rebuild
Cool ! I have a 1970 C-10 with a 350 and a 3 speed automatic. I want to eventually have a newer transmission put in that will allow for good highway speed , etc.
Being that I am NOT a mechanic, can I use a transmission from an '80's Camaro or something like that ? What is a good suggestion for a good, solid, used, inexpensive 4 or 5 speed auto transmission for a 1970 C-10 ?
Thanks,
Mike
PS- I'm new here as of June 2011.
michaelofpetaluma is offline   Reply With Quote
Old 06-23-2011, 01:56 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like a great start to a sweet shortbed truck.
Keith
Convert to disc brakes.
Old 06-23-2011, 06:40 AM   #4
Buckeye Puller
Thanks,
Mike
When it comes to putting an overdrive transmission into an older truck like these, there's going to be some fabrication work. IMO a 700r4 is a good easy swap. It would give you an overdrive without a lot of electronics and is a fairly easy swap.
Old 06-23-2011, 12:57 PM   #5
michaelofpetaluma
Thanks for the info !
Old 06-24-2011, 08:11 AM   #6
Buckeye Puller
I found this picture on my truck last night and thought I would share it. This is a picture of what I started with. If I can find the rest of the pistures I will post them too.
Old 06-29-2011, 10:03 PM   #7
RCbowtie69
RCbowtie69's Avatar
COOL!!!! keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
