06-22-2011, 01:28 PM | #1 |
So im looking for a compressor on craigslist
IHAVE no idea how big i need or how small .. hp cfms gallons.. i need.. id like to be able to run a da and a paint gun.. but i have a feeling it takes a big one to run tools.. what can i get away with to run a primer gun?.. im looking for cheap cheap....
06-22-2011, 01:34 PM | #2 |
Watch out for your cornhole !
Re: So im looking for a compressor on craigslist
A DA is an air hog. You need a good 80 gallon 2 stage unit, at a minimum, to efficiently run one for very long stretches.
If you're shopping used (smart man) Quincy, Champion and Speedaire are some top of the line brands. A majority of the others like Ingersoll Rand, Husky, Cambpell Hausfeld and the like are Chinese made nowadays and won't give the long term service as one of the premium brands.
06-22-2011, 02:10 PM | #3 |
Newbee
5 HP minimum to run a DA for any length of time. Get one with a cast iron pump,oil lubed, belt driven. All of the above brands are good. Stay far away from anything that is close coupled (motor and pump are attached together).
06-22-2011, 02:18 PM | #4 |
All compressors have a delivery rating of xx scfm (standard cubic feet per minute) at xx PSI. You need to look at all the tools you'll likely be using and get a compressor that will deliver at least the scfms @ PSI needed, more would be better as the compressor will cycle less. It's tough to work in a garage that has the compressor running all the time. You can look on-line at various tool suppliers for air tools and ratings for each.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-22-2011, 02:52 PM | #5 |
You need a 10-12cfm or better unit for air-heavy applications.
Ingersoll-Rand has 2 different levels. The basic Home Depot level may not be much, but the commercial ones will run with anything out there. That's what I have and I am very impressed with it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
