gas tank for a 54 truck
want to install a gas tank under the bed of a 1954 truck.am wanting to have the filler tube out back behind a flip down license plate.Any suggestions?
Re: gas tank for a 54 truck
I used a 69 chevelle then shortened the neck ,also used the factory tank supports, have lots of pictures if you like
http://67-72chevytrucks.com/vboard/a...1&d=1308792484 |
this is great just what i was thinking about.I have an extra gas tank out of my 69 gto and i had it in my mind to see if it would fit.This is what i want to do,How did you shorten the neck? Were did the roll pan came from and hinge for the plate?Did you make the strap holders?What sending unit are you using.What year is this truck?Like to see more of the truck too.
straps are factory replacement for that tank,so the straps from your gto should be the same.I ordered everthing new from Spectra premium,tank mounting straps and sending unit,and its out of a 70 chevelle 20 gal not a 69 my mistake,69's are 18 gal. The door i had made up at my local sheet metal shop and the hinge is from your glove compartment door.but i had to rework the spring tension to keep the door up. I'm also installing a standard cabinet door magnet latch to make sure it stays up. Mine is a 54 gmc Canadian.http://67-72chevytrucks.com/vboard/a...1&d=1308830969
Sorry i forgot, the neck i cut right at the rib and the neck just slips inside so it can be soldered up, but you have to be careful.
A few more pic,s still working on it.http://67-72chevytrucks.com/vboard/a...1&d=1308832368
nice pics!the rake looks good! you did the tank right clean looking.Will that sending unit work with your after market gauges? I had to (c) my frame for the rearend.did you have to do that?Am about to put the cab on.I replaced the fire wall with a *****en smooth firewall.New front floor boards,cab corners and driver side cowl panel.once i get the tank on then the bed will go on.i should have alot more room in the shop after that.once i figure out how to put pics here i will send some your way.were did you get the roll pan?
The sending unit is O.E.M for Chevelle also ,haven't got that far on mine yet on the gages.The roll pan i got from my local supplier but i believe it's a MARK-k product
I had a used tank out of a 69 gto.Set it in place but it doesnt fit.This truck is set up with a leaf spring rear end.I looked at your and you have a four bar set-up.I can see your fitting in nicely.I have been surfing the net trying to find something to fit it.Any suggestions?
that is a pretty sweet set up i just ran mine up in the bed today. Should have waited for my roll pan to get here. Looks really good.
The gto tank from spectra looks to be the same as the 70 chevelle 39 1/4 x24 1/2 x 7 3/4 my tank fits between the frame rails at the front then the rails get wider from there.You could try a 68 chevy 2 (nova) they are 38 x19 3/8 x 7 3/8 . The other problem you will have with these type of tanks are getting the exhaust out the back, but i'm not doing that.
were did the tank come out of?
#13 |
Not sure what you mean, or was that question meant for fist5366
#14 |
it was meant for fist 5366. hey brikar didnt the nova gas tank fill up from the side not out back or did that change in 68?
#15 |
You can go to spectra's web site and click on E-catalogue then you can look at any make and model of tank you can think of, they all have the dimensions and pictures.The 68 chevy 2 is still rear filler and the 67 looks to be the same, but with no filler neck and smaller size.I just went with chevy so I'd have more luck with the sending unit working with my gauges.The web site is www.spectrapremium.com good luck
#16 |
How about some pic's
#17 |
i believe its out of a chevelle.
#18 |
Whatever you do, DO NOT WELD A USED GAS TANK.
#19 |
handfull54-it will be new just trying to find one to fit between the leaf springs(33").and fill from the rear.It is looking like one out of a van and would have to relocate the filler neck.How is yours set up?
