Old 06-22-2011, 02:24 PM   #1
truckster
truckster's Avatar
Replacing the Dash
Is the dash bolted in or welded or both? I'm talking about the actual dash, not just the cluster or the dash pad.
Thanks.
truckster is offline   Reply With Quote
Old 06-22-2011, 02:49 PM   #2
MARKDTN
Re: Replacing the Dash
Pretty sure it's welded in
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-22-2011, 02:52 PM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
It's both. There are 3 bolts on each side and spot welds running across in the windshield lip area. You would need to remove windshield to do it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-22-2011, 02:52 PM   #4
1972RedNeck
1972RedNeck's Avatar
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-22-2011, 03:03 PM   #5
truckster
truckster's Avatar
Thanks. That's what it looked like to me. My buddy wants to take the dash out of one of his trucks and put it in another.
Old 06-22-2011, 03:41 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I think the Factory Assembly Manual shows it to have 27 spot welds.....
Member Nr. 2770
Old 06-22-2011, 03:44 PM   #7
Shane
Shane's Avatar
from prior experience, it has at LEAST 27 ... felt like 127 when we were drilling them out.
Shane is offline   Reply With Quote
Old 06-22-2011, 03:57 PM   #8
Dano69c10
Dano69c10's Avatar
As long as the top of the dash is not damaged, I usually cut the dash under the dash pad. I call it it cutting along the dotted line. I unbolt the front of the dash and then I weld up the new front. Cover the welds with the dash pad and no one is the wiser. I once drilled out all of the spot welds along the windshield bottom and swore I would never do it again! I've done alot of non-a/c to a/c conversions this way, also hacked dash to non-hacked dashes. Never have to remove the windsheild, just protect it from cutting and welding.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 06-22-2011, 06:53 PM   #9
dingesb
dingesb's Avatar
Thanks for the tips guys! I've really been wanting to convert my '68 from non a/c to a/c and I think you've just convinced to go for it!
94 GMC Sierra GT with 66k original miles,'41 Chevy SOLD, '68 Chevy 1/2 2wd-2nd owner SOLD, '72 Chevy 3/4 4wd SOLD, '08 Chevy 1/2 4wd-service pickup, 2005 GMC 1/2 4wd 4 door lifted-my toy-SOLD, 2007 GMC Yukon XL Denali, 2009 Harley Street Glide
dingesb is offline   Reply With Quote
Old 06-22-2011, 07:28 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If that's the only reason....are you using aftermarket AC? If so, I'd think that using aftermarket outlets would be preferable. I had an air cab and in my opinion, the aftermarket outlets are pretty nice. If you wanted it to look vintage, you should be able to get the dimensions from an air cab, cut the holes in your dash and add the outlets. The factory AC controller will fit the hole that is already there. Aftermarket AC bulkhead connectors are way cleaner than the factory unit that takes up so much room under the hood. My new cab is a non-air cab and will be getting an aftermarket system, when the time (and money) is right.
Meanwhile, I've got a complete factory HVAC system in my garage that I will NOT be using..including the vents, plenums, etc.
Member Nr. 2770
Old 06-24-2011, 07:26 PM   #11
dingesb
dingesb's Avatar
I'm not dead set on using a factory style a/c, I'd just like a/c! My '69 doesn't run so I don't really have anything to use for comparison. I've never rode in a factory a/c '67-'72. From what I've been told it's comparable to a '73-'87 or worse. I've owned 4 of those with a/c (and 1 without) and they weren't the best systems out there! What aftermarket would you recommend? I've heard good things about Vintage Air...
Old 06-24-2011, 11:42 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Maybe you need a new post, asking which aftermarket AC (HVAC) system is the best.
Member Nr. 2770
