Old 06-22-2011, 04:33 PM   #1
CaptHutch66
Ooops! Wonder what that costs?
CaptHutch66's Avatar
Question 3" front lower which headers Full or Shorty's?
If I'm going to stay around a 3" lower in the front w/a 350SB would full lenght headers be a problem? Or.....should I run the shorties? Would like to get it right the first time and not have to swap out after! Thanx, Hutch
Hutch.....Metro Atl Fireman 29 years
1952 GMC 228 w/4spd Hydra Matic (SOLD)
1966 GMC stepside Shrtbed...350 w/Turbo 350 auto
CaptHutch66 is offline   Reply With Quote
Old 06-22-2011, 05:18 PM   #2
kieth
kieth's Avatar
Re: 3" front lower which headers Full or Shorty's?
Here are a set of camaro 67-68 headers, they are not full length kind of a mid length.
Kieth http://kieth.smugmug.com/Trucks/66-G...970_g7MqS-A-LB
350sb 700 r4 91 motor mounts and brackets 91 burb and a tubular crossmember.......
kieth is offline   Reply With Quote
Old 06-22-2011, 06:13 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If your not dropping any more than that I dont see why you couldnt run full length headers. if you were dropped 5 or 6 then you should be worried.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-23-2011, 01:00 AM   #4
Captainfab
60-66 Nut
If you're running an automatic trans, you should be able to get away with running either the passenger car headers like Kieth posted, or maybe the Hedman #69230 headers. Those are specified for a 4x4, but they don't hang below the frame.
Old 06-23-2011, 03:29 AM   #5
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I am almost at 5 inches of drop in the front and there is plenty of room in mine for full length headers. A set of headers to fit a late second gen F-body would actually be a good fit.
fryer1979 is offline   Reply With Quote
Old 06-23-2011, 03:39 AM   #6
roofingbloke
In my opinoin i would allways keep the exhaust system tucked up as much as possible, not just incase you get the lowering bug and go lower, but also the more you tuck the exhaust up the least likely you are to hit anything,
headman hedders 69640 seem to offer a good amount of clearence,
roofingbloke is offline   Reply With Quote
Old 06-23-2011, 08:53 AM   #7
kieth
kieth's Avatar
I really had not planned on lowering my truck a lot but I did want to make it tidy so along with the shorty headers I cut out the center crossmember on both sides so If I wanted I could route the exhaust even with the center of the frame. The only thing in the way is the stock e brake cable routing and that can be moved easily.
http://kieth.smugmug.com/Trucks/66-G...510_hyAAL-A-LB
Old 06-23-2011, 10:24 PM   #8
1964c-10
1964c-10's Avatar
my full length Hooker 2452's hang about 3" below the frame
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
1964c-10 is offline   Reply With Quote
