Old 06-22-2011, 04:37 PM   #1
wldcat10
wldcat10's Avatar
Need Headlight Help Please!!!
Hey guys I need help! I was checking out my water pump on my '70 c-10 the other day just before it got dark out. So I checked it and took it for a spin around the block. When I went to turn on the headlights, they didnt turn on! All other lights are working. Parking lamps, tail lights, and side markers are all on and working. Only my headlights are out. I've never had this happen and don't know where to start? Any Ideas on what it could be? Any help is appreciated, thanks!
1970 CST/10 LWB 350
1984 Blazer
wldcat10 is offline   Reply With Quote
Old 06-22-2011, 04:57 PM   #2
70truckguy
70truckguy's Avatar
Re: Need Headlight Help Please!!!
Try kicking the dimmer switch back and forth from bright to dim a couple of times. They seem to go out every few years. Be rough with it.
Rich
1970 C/10 Step, 383/700R4
http://67-72chevytrucks.com/vboard/s...d.php?t=466601
70truckguy is offline   Reply With Quote
Old 06-22-2011, 05:19 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Check the blue wire at the dimmer switch for power. If you have power on it then pull the plug on the dimmer and jump the blue wire to either the tan wire or the green wire and see if the headlights come on. If they do then the dimmer switch is bad and if they don't then the problem is in the wiring from the dimmer switch to the headlights.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-23-2011, 06:37 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Pull switch to on position and wiggle connectors at the back of each headlight. I've found that dirty connections there are quite common.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-23-2011, 07:15 AM   #5
72BLUZ
72BLUZ's Avatar
mine did that very same thing, ended up having to install a new switch
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 06-23-2011, 07:33 AM   #6
mrein3
mrein3's Avatar
If the switch or the plug to the switch is bad, do the headlight relay upgrade. WAY too much current flows through those wires. High current = heat = voltage loss = melted plugs and dim, yellow headlights.
A simple search in this forum for "headlight relay upgrade" will yeild many posts and many diagrams on how to do it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-23-2011, 10:13 AM   #7
cdowns
cdowns's Avatar
a common problem is the connector to the dimmer switch// the wires tend to get brioke off and no power to dimmer switch result in no headlights
Old 06-24-2011, 01:08 PM   #8
wldcat10
wldcat10's Avatar
Thanks everyone for thr input!
1970 CST/10 LWB 350
1984 Blazer
Old 06-24-2011, 01:24 PM   #9
leddzepp
Moderator
leddzepp's Avatar
This would be my guess.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
