Old 06-22-2011, 06:22 PM   #1
DANTIP
DANTIP's Avatar
Radiator/Shroud Problem
I helped diagnose a cooling problem that only occurred at idle with the A/C on. This truck had all new cooling parts (radiator, hoses, water pump, thermostat, clutch fan, etc.). The truck would overheat in traffic.
I received a picture like this one (I chose this one because the gap is so evident) and was able to help the owner diagnose the problem. Notice the poor fit of the shroud to the radiator (you can see the fan clutch through the gap). At idle, the only air going through the radiator was being pulled by the fan. The air is going to follow the path of least resistance. The gap shown is an example of how an aftermarket radiator may not fit the shroud properly. The truck would do fine on the highway with the A/C on but at low speed, when the fan was supposed to be pulling air across the condenser then through the radiator, too much air was sneaking through the unintended gaps between the radiator and shroud. Another cause of this would be incorrect radiator mounts (4-core mounts with a 3-core radiator for example).
Long-Story-Short, make sure this gap is very narrow or find some way of sealing it up. Otherwise you can expect low-speed cooling problems.
DANTIP is offline   Reply With Quote
Old 06-22-2011, 06:34 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Radiator/Shroud Problem
people dont often realize how important a shroud is to a cooling system.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-23-2011, 07:35 AM   #3
MagmaJct
MagmaJct's Avatar
Good one. I was just involved in a discussion on this board where the owner was considering going to a colder thermostat to solve this very issue. Eventually he revealed he had no shroud because it wouldn't fit the fan. (Fan was too big.) Unfortunately, I'm heading out the door and have no time to link to the thread. (I can type faster than I can find the thread.)
Cheers!
MagmaJct is offline   Reply With Quote
Old 06-23-2011, 02:16 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Something that I looked at numerous times is; the lenght of the After Market clutch fans. I have a OE one that went inop and purchased a replacement for NAPA. The shaft was about a 1/4" shorter in length than the OE. I looked at a couple different brands and all have the same diminsions. I don't like the fan sitting a 1/4" further out of the shroud. Beside inserting a spacer, haven't figured that one out.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 06-23-2011, 04:46 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The picture looks like they are using the wrong radiator clamps. They look to be 4 row clamps on a 3 row radiator. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-23-2011, 04:54 PM   #6
elf w/capital T
...i know its ghetto but it works and looks clean, i cut a piece of metal, and bent it and it covers that little gap and is just flat.... just my two cents, good luck
elf w/capital T is offline   Reply With Quote
