06-22-2011, 08:23 PM | #1 |
Stock wheel horn contact question
Posted earlier in the wrong section: my Bad.......
Trying to get a stock wheel back on my 72 Blazer after removing a aftermarket wheel. How does the horn contact and spring fit into the canceling cam? I can't find a real assembly photo but the LMC catalog show the contact pin first(wide part down), followed by the spring then the plastic spacer. No way this can work. Only way I can figure is spring first, then plastic spacer followed by contact pin(wide side up) but the spring seems really weak. Any inputs appreciated. Thanks, Tony |
06-23-2011, 08:12 PM | #2 |
Re: Stock wheel horn contact question
following this one
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
06-27-2011, 07:36 PM | #3 |
Ok all figured out;
Thanks to Sharpie for providing me a stock cam cancel with the Horn contact in it. The LMC catalog is wrong and the parts they sold are the wrong size. Catalog shows contact first wide-side down, spring then the retention piece. Correct way is spring first, contact wide-side down, then the retention piece. The hole in the cam cancel tube is .245 diameter and the contact LMC sells is .275 inches wide; a no fit condition. I put the contact into my Dremel tool and spun it on a sheet of sandpaper until I got to .240 diameter; works perfect.............now. Real fix was installing Sharpies stock part; Thanks again. Tony |
06-27-2011, 10:47 PM | #4 |
Thumbs up for Sharpie ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
