Old 06-23-2011, 01:16 AM   #1
Rede
Rims for 14.5" wide tire?
I did some horse trading and pickup a set of 38.5"x14.5" thornbirds just for bombing around town. (39.5"x18" boggers for the trails)
I was cautioned by the local tires shop here about making sure my rims (16x8) have enough offset/back spacing to clear my steering components?
I'd preffer not to run a massive spacer if I can get away with it.
Anyone have any first hand experience?
Ideally I'm just looking for your basic steel, spoked rim. (next to no budget)
Rede is offline   Reply With Quote
Old 06-23-2011, 01:17 AM   #2
Redcap
Re: Rims for 14.5" wide tire?
Look for some 16x10s. What bolt pattern?
Redcap is offline   Reply With Quote
Old 06-23-2011, 01:22 AM   #3
Rede
wow that was quick!
I've checked around kijiji for the past few days, but I'm not interested in 22's
What offset/back spacing will I need if I have to order some?
Old 06-24-2011, 08:09 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
How much lift do you have? What axles? SRW or DRW?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-24-2011, 09:29 PM   #5
Rede
1980 chev 1/2
dana60 (1986 1ton, need steering block)
10.5" 14bolt
6" lift with butchered fenders
I don't know what the srs and drw meen. :?
Old 06-24-2011, 10:23 PM   #6
thirdstreettito
Resident of Here
SRW = Single Rear Wheel
DRW = Dual Rear Wheel
If it's SRW maximum backspace I'd say is 3-4". If it's DRW, maximum backspace around 9". You can swap SRW hubs for DRW hubs if you want to.
~Bradley~
Miss having a truck
Old 06-24-2011, 10:37 PM   #7
Rede
Ahh it's single like most 1/2 tons :p
The rear isn't an issue I'm sure as there are 39.5/18/15 on the rear sitting in my driveway.
It's clearing the tie rods and all that on this new-to-me dana60 front that I'm a worried about.
I can get these other 14.5" wide tires on my spare 16x8 rims, but with the 3 inches of tire bulging out, I'm pretty sire I'm going to see some "rim job" action....and not in a good way. :|
Old 06-25-2011, 07:01 AM   #8
LONGHAIR
Most 1/2 tons don't have Dana60s or 14 bolts either.....details like that are fairly important in the original post.
But I am missing the point of your original question? Why would you think that there would be clearence issues with the steering parts, with an 8" wheel? You would have to have a very late-model wheel with a lot of negative off-set to even get close.
The only thing the wheel could ever contact would be the knuckle where the tie-rod connects....the "bulge" of the tire is irrelevant, it's diameter is too great to contact that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-25-2011, 01:22 PM   #9
Rede
These tires were originally mounted on some decent looking alluminum 12" rims but for whatever reason, they weren't clearing the tie rod knuckles and when he would back up there would litterally be fine alluminum shavings coming off.
By the time he realized what was going on (new to him 1/2 ton with 10bolt front diff) the inner lip on the front rims were pretty thin and there are some nicks in the tires as well from digging in. I had a tire shop check out the tires and he said it was cosmetic damage to the tires, but the damaged to the rims was enough for them to tell me that they wouldn't even mount a tire on them, ever.
Which is why the tire shop said they could order any size of rim, but I'd need to figure out the back spacing/offset so I didn't end up doing te same thing.
Old 06-26-2011, 08:26 AM   #10
LONGHAIR
A 12" wheel is a completely different situation.
With a standard 8" steel wheel, it's a non-issue.
Old 06-26-2011, 11:17 AM   #11
What diameter rim do you need? I always ran 10" (or 9.75 x 16.5 wheels with 14.50s. Never gave back space a thought. I was never asked and white spokes were only offered one way. The backspace is in the range that basically every wheel made was,before tires and wheels got retarded on sizes. If you're going with el cheapo white spoke wheels,just get 10",that's all. The tire store guys should already know this.
Old 06-26-2011, 04:47 PM   #12
Rede
lol who knows what the tire guy was thinking...
I didn't know the answer either but I figured there's gotta be someone here who would
There's tires are 16".
Will they clear the dana60 calipers and what not without any caliper grinding?
I've...never been with a dana60 before...*gets all shy and twists a toe into the dirt*
Old 06-27-2011, 04:48 AM   #13
Redcap
16" rims should clear just fine.
Old 06-27-2011, 04:55 AM   #14
Rede
Just to clairify, 16x8 or 16x10 will clear?
Old 06-27-2011, 06:37 PM   #15
Altec
Getcha Pull
Altec's Avatar
Both.
Be warned, those thornturds are going to be worse then the boggers... Worst tires ever made...
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 06-27-2011, 08:04 PM   #16
Rede
Originally Posted by Altec View Post
Both.
Haha ya I seen this set in action with 6" of snow...if he got off our path, he was screwed. Didn't help that his transmission wouldn't shift out of first so he couldn't get any wheel speed.
These are jus for in town as the 33" KL71's that i had looked like training wheels with 6" lift and butchered fenders.
I'm going to ask a few places about using a tire groover to get a few lines cut in for improved winter traction.
Next year I can look for a better pair of 35+ tires.
Tomorow I'll get one of these tires mounted and pickup the needed steering arm block to see how it fits.
Old 06-28-2011, 09:58 AM   #17
Personally,I see Thornbirds as novelty tires. Never ran them,but they don't impress me just looking at them. Why are no other tires anything like them? What is their specific design intended for? The don't look as good as any of the other Interco mud tires and they don't look like they'd be good for sand. I think Xterrains would do just as well in snow and mud (not the best) and they are great sand tires. That's what I run for sand. Then use Swampers for mud. A/Ts are middle of the road for everything but hiway,but suck in mud. Probably just as good as Thornbirds though.
Old 06-28-2011, 11:51 AM   #18
Rede
Can't say I'm a fan of them either, but I traded for a greasy th400/np208 combo I picked up for 250 bucks.
They were the cheapest thing I could find between 35" and 40" tire.
Anything else looks like pizza cutters
Unless I find someone else who wants to trade something decent sized for them, I'll just use them as is and look for something else for rubber next year.
