Old 06-23-2011, 02:44 AM   #1
TrkEnvy
Pulling ignition problem
I am planning to restore the dash in my 71 next, but I have a problem. The truck was not running when I aquired it and I was not given any keys for it. I have seen how to pull the ignition cylinder if you have keys, but since I dont any tips? I dont wanna do any damage to the dash sheet metal getting it and the trim ring out. Thanks
Brock
TrkEnvy is offline   Reply With Quote
Old 06-23-2011, 04:35 AM   #2
Autoblueprint
Autoblueprint's Avatar
Post Re: Pulling ignition problem
Brock
Replace the Ign switch and door lock key cylinders. You need a special tool to remove and install the ign cyl trim ring. The Truck Shop in Orange, CA will have what you need.
http://www.truckandcarshop.com/6072.html
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 06-23-2011, 12:32 PM   #3
Frkypunk70
Frkypunk70's Avatar
If you have a old set of the regular style gm keys try sticking one in there. After 40 years of use alot of these gm ignitions will take any key. My truck will start with old keys my father had laying around. Its worth a shot.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 06-23-2011, 11:35 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=335168
LockDoc
Leon
