Old 06-23-2011, 10:06 AM   #1
slowboy
slowboy's Avatar
Quadrajet 4MV
Put remanufactured Quad 4MV on my '72 GMC 350. Choke plate would close for startup, then open slightly, like it was intended to do. Now choke plate has gotten where it won't close at startup, it sticks in open position. Now to start truck, I have to manually open throttle and push plate closed by hand before it'll start. Can someone tell me how to fix this choke plate problem...preferably not by buying different type of carburetor and using mine for a "boat anchor"? LOL ! !
slowboy is offline   Reply With Quote
Old 06-23-2011, 11:15 AM   #2
RustyParts
RustyParts's Avatar
Re: Quadrajet 4MV
I had one do that once, I had to remove the plate and file the outside edges to loosen it up.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-23-2011, 12:35 PM   #3
406 Q-ship
406 Q-ship's Avatar
Re: Quadrajet 4MV
How good is the thermo-coil on the intake? If it is weak it will not pull on the carb choke mech. hard enough, it might be more noticeable in warmer weather.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 06-23-2011, 03:41 PM   #4
geezer#99
geezer#99's Avatar
Re: Quadrajet 4MV
Take a pic for us before you start it of the side of the carb.
Old 06-23-2011, 04:31 PM   #5
Wrenchbender Ret
Re: Quadrajet 4MV
Something is binding. The spring on the pulloff should snap it shut as soon as you open the throttle. It may be like Rusty says. The choke plates might be be rubbing. If not then the linkage is binding. You need a good choke thermostatic coil on that model. It has to get hot enough to overcome the sprint on the pulloff.
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2011, 05:21 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Quadrajet 4MV
Yep... had one on a '71 El Camino do the exact same thing. New thermo-coil thingy and it was fixed.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-23-2011, 06:05 PM   #7
geezer#99
geezer#99's Avatar
Re: Quadrajet 4MV
Apologies wrenchbender. You've got it backwards. Rod from thermo-coil pulls downward when cold which closes choke plate when you step on the pedal. When it starts vacuum pulls the choke open using the pulloff pot. Amount it opens is controlled by the bent arm hooked to the slot in the pulloff. When coil heats up rod pushes upward and when you tap the throttle it will kick off the high idle cam.
OP says it won't work unless used manually. I suspect thermo-coil or linkage rod popped off.
A pic will tell a thousand words.
Old 06-23-2011, 06:20 PM   #8
Wrenchbender Ret
Re: Quadrajet 4MV
I dont have it backwards. On that model carb the spring on the pulloff helps close the choke untill the vacuum pulls it partway open like you said. The choke therm coil has to overcome the spring tension on the pulloff or the choke will reapply on full throttle when the vacuum is low. I have had to cut some coils out of the spring on some to get the right adjustment. I have worked on hundreds of them.
Old 06-29-2011, 01:21 PM   #9
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
I know I do need choke coil, rod, and cover/housing...can't seem to find where to buy these anywhere.
One other thing...shouldn't I be able to close choke plate manually from pull-off side of carb...can't do it there...just from top of carb [seems like I use to]?
Old 06-29-2011, 04:30 PM   #10
Wrenchbender Ret
Re: Quadrajet 4MV
Yes you should be able to close it with the linkage but the throttle will have to be open a little to let the fast idle cam rise. If not you have something hanging or the linkage is going over center.
Old 06-29-2011, 09:53 PM   #11
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Quadrajet 4MV
Edelbrock sells them.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-29-2011, 10:12 PM   #12
ARTISTIC
Re: Quadrajet 4MV
I bought hard to find (read impossible) for Qjets here:
http://www.quadrajetparts.com/
You may have some luck or point you in the right direction.
I was at a wrecker today and even in this area found 5 - 10 Qjets of all kinds of configurations.
I had the same intake configuration on one of my old trucks and it was a pita to get working correctly - even worse when you convert to an aluminum intake without the recess.
My current carb has that exact setup with no intake choke spring or elec choke and it works fantastic. My problem was the lack of the spring on the vac takeoff. Bought the whole setup from the guys at the above link and problem solved!
ARTISTIC is offline   Reply With Quote
Old 06-30-2011, 08:06 AM   #13
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
my previous quad I had on truck I ended up removing linkage and pulloff and running a cable from carb to inside of truck cab because of missing choke rod and housing...worked fine...I was hoping to find rod, housing and new coil and hooking this one up like it is meant to be...since I don't have original housing and rod, being the try anything I can think of type of person, I made a housing, and a rod out of a piece of coat hanger...yep...a piece of coat hanger...I know rod is, I believe, suppose to be 1/8" material, but didn't have anything that thick...choke plate was working as suppose to, for a while...I have noticed that the [I think it's called] the secondary lockout lever is just sorta 'dangling', and loose instead of sitting the way it should be
Old 06-30-2011, 08:40 PM   #14
oldgold70c10
Who's got steelies?
Re: Quadrajet 4MV
Is everything free with the carb off the engine? If yes, then from the photo, it looks like your coat-hanger choke rod may be able to jam in the slotted hole, locking everything up. You may want to adjust how you've got it bent so it can't jam. Also, is it long enough so that the coil on the manifold will open the choke?
My Truck Page
My Youtube Channel
Old 07-07-2011, 12:55 PM   #15
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
found original 1/8th inch rod for choke...will see what happens in the morning
Old 07-08-2011, 01:30 PM   #16
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
1/8th inch rod wasn't original, but after I took a picture of carb this morning, I saw that rod was too long, and hitting choke linkage at the top. This was preventing choke from closing. After modifying rod, [had to shorten it about 3/16ths of an inch] I noticed that choke still wasn't closing completely. Took choke coil and put it in freezer for 10 minutes, then put back on truck. Choke worked perfect, and truck fired right up. Probably work fine if it was winter time. I guess now the choke thermostat coil is going to have to be replaced. Must be wore out and lost some tension.
Checked with Eckler's, and can't believe they're wanting $25 for this thermostat. Anyone know of cheaper place to get one?
Might try junkyard. Don't know if I can find one, or the right one. Probably end up paying $25 anyways. Hope it's free shipping. Ain't a tightwad...on Social Security Disability and have limited income. Have to watch my pennies.
Old 07-24-2011, 09:23 AM   #17
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
Ok...bought new thermostat coil and put it on.
I've been trying to hook my divorce choke up on Qjet. It seems that if I make the rod that goes from thermostat coil to choke linkage short enough to close choke flap all the way, when engine warms up, the choke flap won't open all of the way. And vice-versa.
How do I fix this problem? I'm no expert on Qjets, and need help please.
Also...what are y'alls thoughts on using port behind choke pull off for vacuum advance?
Old 07-24-2011, 09:44 AM   #18
geezer#99
geezer#99's Avatar
Re: Quadrajet 4MV
Even though your home built coil cover looks nice maybe you need to install a factory one. JMHO
Old 10-02-2011, 10:40 AM   #19
slowboy
slowboy's Avatar
Re: Quadrajet 4MV
where can I purchase this choke coil cover to fit my truck...
Old 10-02-2011, 02:26 PM   #20
GASoline71
GASoline71's Avatar
Re: Quadrajet 4MV
You can't... they aren't available.
But I have the factory cover and choke coil from my ol' '71 El Camino. Should be the same thing that came on the trucks. You can have it if you want it.
Send me a PM.
Gary
Old 10-02-2011, 07:23 PM   #21
406 Q-ship
406 Q-ship's Avatar
Re: Quadrajet 4MV
Edelbrock sells the coil, cover, and rod. I just put one on my 67 C10 that has an engine from a 1974 passenger car.
S/B Chevy Performer manifolds (Divorced Choke) 1931
