Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 06-23-2011, 06:53 PM   #1
mbgmike
Fel pro gasket kit week end special
THIS WEEKEND ONLY $30.00 PER SET $10.00 SHIPPING ENDS 6/26/11 AT NOON
Description: Complete gasket overall kit
1967-80 265, 283, 302, 307, 327, 350 V8 Engines
Stock rebuild gasket kit
Features: - Perma-Torque head gaskets (2)
- Perma-Torque intake gaskets with blue Teflon coating
- Blue stripe cork rubber valve cover and oil pan gaskets with rubber end seals
- Water pump gaskets
- Timing cover gasket and oil seal
- Water outlet gaskets (thermostat)
- Valve seals
- Exhaust gaskets
- Fuel pump mounting and distributor mounting gaskets
Other:
Characteristics: Part Type: Engine Gasket Sets
Part Number: FEPKS2600
Gasket Set Type: Full gasket set
Head Gaskets Included: Yes
Intake Gaskets Included: Yes
Valley Pan Included: No
Oil Pan Gasket Included: Yes
Rear Main Seal Included: Yes
Exhaust Manifold Gaskets Included: Yes
Exhaust Pipe Gasket Included: No
Valve Cover Gaskets Included: Yes
Valve Stem Seals Included: Yes
Water Pump Gaskets Included: Yes
Timing Cover Gaskets Included: Yes
Timing Cover Seal: Yes
Water Neck Gasket Included: Yes
Fuel Pump Gasket Included: Yes
Distributor Gasket Included: Yes
Fuel Injector O-Rings Included: No
Upper Intake Manifold Plenum Gasket Included: No
Head Fasteners Included: No
Quantity: Sold as a set
THATS 15.00 LESS THAN JEGS OR SUMMIT
SAME DAY SHIPPING IF ORDERED BEFORE 5:00 EST
mbgmike is offline
Closed Thread
