06-23-2011, 10:09 PM | #1 |
automatic trans mount?
what is the reason for the upper part of the mount ? is there any reason i cant cut it off ? having fitment issues after having the frame straightened without it in place.
thanks josh
My build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=348729 |
06-23-2011, 10:32 PM | #2 |
its all about the +6 inches
Re: automatic trans mount?
you talking trans mount, or crossmember?
06-23-2011, 10:50 PM | #3 |
Ever since last year that's how I've been running; see this thread.
Auto Transmission Crossmember mod.
'69 Fleet It ain't yours, if you didn't build it! |
06-23-2011, 11:05 PM | #4 |
crossmember. and thanks for the link. what type of hp/tq are you running dano? mine needs to hold up to 450+ hp/tq . may need to weld in a support peice.
06-24-2011, 12:27 AM | #5 |
It's a stock set-up, that's why I'm not concerned. Stock 350V8/TH350. I feel the x-member w/o the top parts is strong enough.
If I was going to run 450+hp, then I think I would remove the rivets to the top part and weld the top and bottom of the stock x-member together to make it a one-piece x-member.
06-24-2011, 06:02 AM | #6 |
the top piece of crossmember helps support the frame rail to resist twisting forces
06-24-2011, 01:24 PM | #7 |
thanks looks like im gonna need to fab something up.
06-25-2011, 12:16 AM | #8 |
With those hp numbers (450+) you don't want to settle on a weak x-member.
06-25-2011, 09:44 PM | #9 |
o trust me the one i make will beable to handle the power plus im gonna x brace the frame figure if i gotta fab might as well do it right the first time.
