06-24-2011, 01:46 AM | #1 |
motor build
im goin to be doin an entire power train swap from an 03 gmc sierra
5.3/4l60e into a 71 c10 lwb i was wondering what all upgrades anyone has done to one of these motors aside from an intake exhaust and a tune cam? heads? headers? ignition? ecm flash? this truck will be a weekend cruiser that im taking my time to build |
06-24-2011, 10:00 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: motor build
Yes all of them have been done and are being done.
If your just wanting a mild driver, then the 5.3 with a performance tune and headers will provide you with around 350HP. with a cam and the above, your looking around 400hp or so. The stock heads should work fine, they are aluminum and flow fairly well, there are more better gooder heads out there though, I think the 317's are on the LQ9 and they are sought after. not sure if they would work on your 5.3 or not though. The 4l60e will need to be built to handle the hp and torque I believe. Ignition should be OK as is, unless your are planning to use a carb. I have a 4.8/4l60e and I estimate the HP at around 300hp without a cam, just tune, headers and Cold Air kit.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-24-2011, 10:57 AM | #3 |
meowMEOWmeowMEOW
Re: motor build
Anything you can name, has been done to these motors.
Heads, cams, intakes, TB, and exhaust stuff are all pretty standard fair around here. There are a few guys going bigger; prochargers, turbo, nitrous etc. If you want to see what these engines can do, check out LS1 tech. They have every combo you could imagine at some point or another.
06-24-2011, 01:23 PM | #4 |
Re: motor build
ok thanks
the motor makes pretty good power right now but as we all know you cant get enough |
06-24-2011, 01:58 PM | #5 |
Always a work in progress
Re: motor build
Heads, cam and intake would really wake it up. Ported 243/799s or some small port AFRs or Trickfolws(205cc intake port) would work. There is always the option of a stroker kit.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
