Old 06-24-2011, 01:21 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
1985 Radiator Options
I didn't want to hijack the thread for a 63-66 radiator so I figured I would start one for my truck.
I planned on getting a new radiator to go along with my swap. Plan 1: I can get a new alum 3 core with dual elec fans from champion for $315. It is set-up just like a stock radiator with the inlet and outlet on opposite sides. Plan 2: Entropy has one with the inlet/outlet on the passenger side and the trans cooler on the driver's side. That 1 costs $699 w/elec fans.
I like the 2nd option bc it cleans up the engine bay but has a hefty price tag. What would you do? Anyone have some pics of their engine bay with the stock style radiator showing how you routed the hoses?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-24-2011, 01:55 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1985 Radiator Options
Nrd, I have the Champion radiator myself, I have dual elec fans also, I like it, it works great, fits with no mods and also has the trans cooler in it. When I looked at this, I thought why spend ( I was looking at Be Cool) $1000.00 for a rad/fan combo? besides if it didnt work out, I had thrown good $ after bad before.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-25-2011, 04:52 PM   #3
Randy83
Randy83's Avatar
where can I find Champion radiators at? Sounds like a pretty good deal for radiator, fans and all....
Randy83 is offline   Reply With Quote
Old 06-25-2011, 06:35 PM   #4
TR65
TR65's Avatar
Randy,
See Ebay
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-25-2011, 08:53 PM   #5
softballnrd27
I am getting mine from reliable radiator
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-25-2011, 10:45 PM   #6
clinebarger
Im using the stock 85 radiator & fan shroud with stock 04 fan, fan clutch & radiator hoses. The only mod I made was soldering a 3/8" adapter to the heater hose nipple on the radiator for the steam hose. It work great! 100+ degrees outside idling in the sun with the A/C on.....No overheating or A/C head pressure problems.
I have terrible luck with aftermarket parts on my own vehicles. It seems my customers & others have better luck
clinebarger is offline   Reply With Quote
Old 06-26-2011, 09:36 AM   #7
Juiced06GTO
I used a radiator out of a 99 Suburban, with trans and oil coolers built in, 40 bucks at the local yard. Then a generic elec fan from summit. The truck runs 190-205 even when towing a 7klb load....
Juiced06GTO is offline   Reply With Quote
Old 06-26-2011, 11:11 AM   #8
Clyde65
Clyde65's Avatar
That is where I got mine
Clyde65
Rebuild of Clyde
support our troops!
Old 06-26-2011, 05:08 PM   #9
softballnrd27
I would use my stock one with an electric fan but it barely keeps my 305 cool(It's a 6cyl truck) and it's an eye sore. When I install the 6.0 I want to clean up the engine bay at the same time. For $310 shipped w/ dual electric fans, I can't beat that. I have read alot of good stuff about champion raditors so i don't really have any issues with purchasing one.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-26-2011, 06:51 PM   #10
Clyde65
Clyde65's Avatar
if I had any issue with them, I would blab it to anyone who would listen. I got a bad fan and I called them, told them about it, they set a replacement that day and I had it is 2 days.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-27-2011, 01:25 AM   #11
HarleyHauler
Did the 99 Suburban radiator bolt right in or did you have to custom mount?.. Can you post a pic?
HarleyHauler is offline   Reply With Quote
Old 06-28-2011, 07:45 AM   #12
Juiced06GTO
I had to custom mount it. It is a little wide for the core support, but it works. I installed a rubber mount on the lower part of the core support then use the stock upper mounts with rubber bumpers installed in them to hold the radiator in.
Old 09-04-2011, 08:43 AM   #13
northeimcustom
northeimcustom's Avatar
just an fyi, the champion with dual fans is down to about 290$ shipped now of ebay from reliable
northeimcustom is offline   Reply With Quote
Old 09-05-2011, 12:11 PM   #14
Bennett68C10
Bennett68C10's Avatar
I just purchased this for my truck, couldn't justify spending over $600.00 for an Entropy setup. I will post pics when it comes in.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-05-2011, 06:37 PM   #15
texastrendz
can you post a link to this, i can not find it. Thanks Daniel.
texastrendz is offline   Reply With Quote
Old 09-05-2011, 08:41 PM   #16
Clyde65
Clyde65's Avatar
http://stores.ebay.com/Reliable-Radi...id=p4340.l2563
Clyde65
Rebuild of Clyde
support our troops!
Old 09-06-2011, 10:42 AM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I run the be-cool and im happy with it, but since the PO put it in the truck when it became a 350 years back, I didn't have to foot the bill for it.
If it wasn't mentioned, the F**d Taurus fan setup is popular for going e-fan on the cheap. A dual fan setup with temp sender from a pick n pull is like $35
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
