valve cover?
After a quick searck looks like I ordered junk{stamped steel/chrome}nonetheless there are 1 hole in each cover{pcv/breather}.Do I need to holesaw another hole for adding oil?Or use the breather hole?Seems like it would drain very slow.Thanks,Mel
Re: valve cover?
ive always used the breather hole.
1972 longbed- 454 1967 shortbed- 355 |
Re: valve cover?
68 SWB Fleet 383 |
Re: valve cover?
cheap valve covers without baffels allow PCV to suck and burn alot of oil in the engine
Re: valve cover?
i drilled a second hole on the driver's side cover (a/c compressor on pass side), its less mess to add oil and i don't have to remove anything but the oil cap to add oil. on the early valve covers, drill right between the hold down bolts, that will put it between the rockers.
#6 | |
Re: valve cover?
Re: valve cover?
![]() Here is the result.Did alittle engine bay clean-up this weekend.The new fill is under the bowtie breather,will end up with more of a oil filler cap but it will work for now. |
Re: valve cover?
with your metal fuel line in contact with the engine block and the rubber hose resting on the heated water hose iit would not surprise me if you'd run into a vapor lock problem from the overheated gasoline
Re: valve cover?
The metal line does not touch the block but the rubber is on the heater hose.Going to add new plumbing/filter from pump to carb.Thanks for the heads up.
