Old 06-24-2011, 03:26 PM   #1
jonessmc87
jonessmc87's Avatar
anybody know a good source for gauge clusters?
I'm looking for a gauge cluster out of a late 80s big truck. It would be cool to have the combined factory tach and fuel gauge, but my main interest is in the factory air pressure gauge. I've pieced together an on-board air system with a york 210 compressor and i would like to have the factory touch in the dash instead of the useless brake light. if you guys know of any sources, im all ears. thanks.
1989 V3500 nv4500/np205 255-85-16 BFG Mud Terrains, 4inch skyjacker kit, 2 inch body lift.
"Yea, it was a fuel supply problem. A rod came through the block and cut the fuel line."
jonessmc87 is offline   Reply With Quote
Old 06-24-2011, 06:32 PM   #2
J Knight
J Knight's Avatar
Re: anybody know a good source for gauge clusters?
I read about a place called Redline Gauge, I don't think they can get u the setup u r looking for but they can set it up when u find one. I have the link at home and ill edit this post tonight.
Posted via Mobile Devicewww.redlinegaugeworks.com
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-24-2011, 08:11 PM   #3
b454rat
If I can find time, local yard has a bunch of big trucks in there out body style. Should be able to get a couple gauges.
I have one that was in a diesel, has the 4k tach with the small fuel gauge, and a dual needle air gauge for two separate tanks.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 06-24-2011, 10:14 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I was going to suggest your local junkyard. I know ours out here used to but the guy closed it and crushed 90% of all his rigs which sucks! Did you try searching the net yet?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-26-2011, 10:08 AM   #5
jonessmc87
jonessmc87's Avatar
yea i've been watching ebay for a while and a few other sites. i can only seem to find the early 73-early 80s gauge style. i was hoping to find the newer style. as far as junkyards. there really isnt any near me that would have a c70 or something of that size just sitting in it.
Old 06-27-2011, 12:01 AM   #6
CamaroChris
Went to a local yard here and picked up an electronic spedo gauge cluster for 20$
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 09-21-2011, 11:47 AM   #7
ky_kid
ky_kid's Avatar
Do you have the diesel cluster?
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 09-21-2011, 08:14 PM   #8
b454rat
I have one yes....pics are somewhere on here...
Old 09-21-2011, 08:45 PM   #9
ky_kid
ky_kid's Avatar
How much would you sell the entire cluster for? I'm assuming it has all gauges... I found a 6.2 for $150 so I'm really leaning towards swapping my 350.
Old 09-21-2011, 10:15 PM   #10
b454rat
I have two clusters left, was gonna hang onto them till I figure what way I want to go. Not 100% sure I want to sell either of them, but I'll post in the classifieds if I do.
Old 09-21-2011, 10:20 PM   #11
Telecasterjoey
I have one but the tach doesnt work I thought it would be cool to have the tach fuel gauge and a clock all in one cluster!
Telecasterjoey is offline   Reply With Quote
Old 09-21-2011, 10:29 PM   #12
J Knight
J Knight's Avatar
Are stock tachs fixable? And I assume no one is repoping them.
John
Old 09-22-2011, 12:26 AM   #13
cr34t3d_by_d4rkd3n
Theyre avability in junkyards varys state to state. Northern state tend to have pressure guages and hydro boost where as more southern thends to have the tachs. And odd ball packages and wierd factory options.
Try lmc. But im telln ya now factory is expensive and usually out of spec. From personal exper. Keep lookn at the junkyards, check anything 73-88 esp the bigblock surburbans. Good luck.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
