Old 06-24-2011, 09:04 PM   #1
68black_betty
68black_betty's Avatar
q jet questions
i got a mildly built 454 prolly around 400 hp at the fly, wanting to throw a quadrajet on there, does anyone know which qjet numbers are the best ones to look for, i know they made some 800 cfms would those work better than the 750 or would it make much of a difference
68black_betty is offline   Reply With Quote
Old 06-24-2011, 10:31 PM   #2
Lee H
Lee H's Avatar
Re: q jet questions
A 750 Q-Jet will work very up to about 450 HP.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-24-2011, 11:59 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: q jet questions
any q-jet will work, as long as it is set up for its ORIGINAL application. Just stay away from the last ones. You probably want to get a 4MV though.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-25-2011, 09:37 AM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: q jet questions
As far as ease of set-up, tuning, adjustment, reliability, go with a 76-77 M4MC. The castings are better. The float position is better. The chances of leaking bottom plugs is virtually nil. Less likely to have warped castings. Integral choke easily converts to electric for no-hassle operation. They are all large venturi castings and will flow up to 850cfm. They have an adjustable part throttle feature that can be easily modified so you can adjust with the engine running. I like Buick models because the small air bleeds make tuning easy, most Chevy M4M-series carbs will have large air bleeds which will make using larger jets mandatory,which makes it harder to set-up. I like the 76 and 77 models because they still have the slot head idle mixture screws, the screwy aneroid-adjusted part throttle was a 75 only feature (though not all 75's had it), and you want to stay away from it. Don't take it all from me, find a copy of Cliff Ruggles book, that's how I learned.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-25-2011, 11:02 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: q jet questions
Shoot, why not try for one of the 850CFM Q-Jets from a Pontiac SD?
Seriously, the 750 will be just fine. If you can find an Edelbrock Q-Jet, they're just right.
Member Nr. 2770
Old 06-25-2011, 08:15 PM   #6
GRX
GRX's Avatar
Re: q jet questions
^^ Great post all around. Q-jets can be made to perform extremely well. But working with them takes a bit of know-how. Cliff Ruggle's book is a must. Upwards of 1,100cfm is possible. A regular on another forum I contribute to just passed 750hp with his Pontiac 428 & Q-jet carb.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-26-2011, 12:31 AM   #7
slikside
slikside's Avatar
Re: q jet questions
X3...I don't have anywhere near that HP (strictly stock) but Cliff is the man when it comes to Q-jets. I used his book, parts, and throttle shaft bushing service. Took my time and it ran like a champ as soon as I bolted it back on.
slikside is offline   Reply With Quote
Old 06-26-2011, 01:00 PM   #8
ubtripn
ubtripn's Avatar
Re: q jet questions
Not to steal the thread I just have a relatd question - can one buy a new Q-Jet? If so, is it any good?
ubtripn is offline   Reply With Quote
Old 06-26-2011, 04:08 PM   #9
oldgold70c10
Who's got steelies?
Re: q jet questions
If you are wanting an older style 4MV carb, look for an Edelbrock 1901 or 1902. M4MV/C is an Edelbrock 1903 or 1904, or 1906. Edelbrock no longer makes these, but if you find one used, or rebuilt it will be much newer than an original one. All Edelbrock Q-jet parts are interchangeable with original Q-jets. Edelbrock models 1903, 1904, & 1906 all use the 1978 and later style base plate that does not have slotted head mixture screws.
My Truck Page
My Youtube Channel
