06-25-2011, 11:13 AM | #1 |
My Carbon Footprint
Best way to cut steel braided line?
Haven't worked with it in a while and I prefer the stock black hose look but I'm doing my race car in it. Can't remember the best way to cut it. Seems like you wrap it very tight with electrical or comparable tape and then cut. But what with? I have cut off wheels. Are those best? What about mama's ginsu knife?
06-25-2011, 11:24 AM | #2 |
Re: Best way to cut steel braided line?
Wrap it in electrical tape and use to cut off wheel to cut it as quickly as possible to minimize fraying. Clamp it in a vise just enough to hold it steady.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
06-25-2011, 11:26 AM | #3 |
I wrap with masking tape and cut with dremel cutoff or fine tooth hacksaw. I also have used a cable cutter but it compresses the hose.
06-25-2011, 11:35 AM | #4 |
06-25-2011, 11:48 AM | #5 |
We used to wrap it and use a cut off tool. We still do but we also sell these kits from Koul Tools
http://www.koultools.com/ they work great and fast if doing a lot of them they range from 25.00 each for a single tool to $125.00 for the pro combo kit. |
06-25-2011, 12:09 PM | #6 |
Has more rust than truck...
On my teflon hose I wrapped with masking tape then used a sharp 2" chisel and 3lb hammer. Squished the hose a little, nothing a pair of pliers didn't cure. Worked great for me.
06-25-2011, 12:12 PM | #7 |
i use duct tape and cut with the 3"cutoff wheel
06-25-2011, 12:24 PM | #8 | ||
Thats exactly I have always cut them..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
06-25-2011, 01:53 PM | #9 |
My Carbon Footprint
Am I the only one that loves using a cutoff wheel in the summer with shorts??? First thing I always do is to remove the safety guard and leave it off. Unlike my air cutoff, that Dwalt spins something fierce and always gets me thinking what would happen if it slipped and went into my thigh.........
(I was going to post a pic of a deep thigh wound off the internet but started to get sick to my stomach when I was looking at them. I think I'll just use scissors!) |
06-25-2011, 02:26 PM | #10 |
Yup you don't need to post a pic for me. I've seen it in person. Cut fast and deep.
The young guy (not me) didn't even know it happened. He was off work for 6 months. A tip. Once you get your hose built flush it out real good. THose fine metal wires could cause you greif for awhile. A missed one once. Drove me crazy trying to find what caused my off and on flooding problem. |
06-25-2011, 02:53 PM | #11 |
My Carbon Footprint
That's a good tip right there...... thanks!
Posted via Mobile Device |
06-25-2011, 05:23 PM | #12 |
Wrap with electrical tape and use a cut off wheel and make sure to rinse with water and blow out with compressed air real good so you don't end up with rubber and steel in your carb or whatever your using it on
Fuzzy |
06-25-2011, 06:57 PM | #13 |
This is how I have always done it (not quite so big of a hammer though) with steel braided line. Make sure the chisel is sharp with no burrs.
06-26-2011, 12:16 AM | #14 |
Junior Member
I found placing a hose clamp on both sides of the cut worked better than tape.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
06-26-2011, 12:32 AM | #15 | |
My Carbon Footprint
I had to come back and edit this though.....once you are done and take the clamps off, doesn't it fray all over the place?? Last edited by prostreetC-10; 06-26-2011 at 12:33 AM. |
06-26-2011, 02:30 PM | #16 |
~Rest In Peace~
get superman to come over and use this laser eyes and cut steel
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-26-2011, 07:11 PM | #17 |
My Carbon Footprint
Willie.....put the beer down! LOL
06-27-2011, 11:05 PM | #18 |
Junior Member
For me, it frayed less. I haven't done a lot of stainless hose. But this worked for the fuel system on my bracket Dart.
06-27-2011, 11:36 PM | #19 |
This is what i used. Works great. Built my hole fuel system for my suburban with this 1.5 times and still cuts great. And no flying metal.cccc
http://www.summitracing.com/parts/SUM-900040/
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
06-28-2011, 07:22 AM | #20 | |
06-28-2011, 09:27 AM | #21 |
My Carbon Footprint
Side note: Just used my acetylene torch and it doesn't work worth a crap!
06-28-2011, 09:35 AM | #22 |
Have you considered martial arts!! You'd have your black belt in no time and could swiftly chop the hose in half!! LOL!!!
06-28-2011, 06:36 PM | #23 |
tape of your choice wrapped tight.Use a cutoff wheel. Make sure to clean the hose out both the rubber and piece of steel play hell with needle and seat assemblies.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
