Old 06-25-2011, 12:36 PM   #1
duckdude
difference?
where can i find out the difference in body parts for 69-72 chevy trucks plus 2x4 vs 4x4
duckdude is offline   Reply With Quote
Old 06-25-2011, 12:53 PM   #2
72supermike
Re: difference?
well, you have asked a very large question. One way that would be good is to look at an LMC truck catalog and they list what year the parts are for when they are different. They also list if the part is for 2wd vs 4wd. but there is quite a lot different from 2wd to 4wd. front suspension, bumper brackets, cab bushings, etc. Spend some time reading here on the forum and you'll get a lot of info as well.
72supermike is offline   Reply With Quote
Old 06-25-2011, 12:58 PM   #3
duckdude
Re: difference?
Thanks 72supermike!
Old 06-25-2011, 01:05 PM   #4
duckdude
Re: difference?
Thanks 72supermike. I had a brain fart, i should have been more specific, i have a 69 4x4 3/4 ton and i have found a 72 2x4 that has a good cab, fenders and hood for a sweet price. Will it fit my 69? I have ordered the catalog you mentioned, i just dont have it yet. Thanks, steve
Old 06-25-2011, 01:09 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: difference?
67 - had no side marker lights, metal grill, sloped hood, and was available with small and large rear window.
68 - had side marker lights, metal grill, sloped hood, and was available with small and large rear window only in very early models.
69 - had side marker lights, aluminum grill with parking lights, new fenders that had a indention for the new aluminum grill, new hood that what straighter in the front, only available with large rear window after '69.
70 - Same as 69. Only the plastic grill insert was slightly different.
71 - new aluminum grill with egg crate plastic insert, parking lights now located in front bumper - other wise same as 69-70
72 - same as 71 except doors had different door panels, and no longer had inserts to install 67 - 71 door panels.
Basic interchange:
Fenders:
67 - no markers. Same as 67 GMC
68 - had markers. Same as 68 - 72 GMC (GMC never used the 69 - 72 Chevy fender)
69 - 72 - had marker lights and indentation for grill (Chevy only)
Hood:
67 - 68 - sloped hood. Only works with 67-68 fenders and grill. Same for GMC
69 - 72 - straight hood. Only works with 69 - 72 grills. Same for GMC
Doors:
67 - 71 - Had inserts to mount door panels
72 - had push in door panel mounts. 72 doors will bolt on to 67 - 72 trucks
Bumpers -
67 - 70 front - no parking lights.
71-72 front - parking lights in the bumper
67-72 rear - ALL
Tailgate:
67-72 - ALL
Radiator support -
67-68 - For metal grill
71 - 72 - For aluminum grill
67 Chevy:
68 Chevy:
69 - 70 Chevy:
71 - 72 Chevy:
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-25-2011, 01:11 PM   #6
67_C-30
67_C-30's Avatar
Re: difference?
Yes, it will work, but you will need to cut out a section of the hump, and nbolt on the transmission tunnel off yor '69 cab. The 72 cab will also have a cable operated gas pedal, and will no have the mirror holes for your '69 rear view mirror. No big deal, but worth mentioning.
My trucks
Old 06-25-2011, 05:52 PM   #7
duckdude
Re: difference?
guys thanks for the help i just bought my 69 yesterday,the body is basicly junk. I have been all over the net reading and looking for parts and I have taken in so much info so fast that its hard to remember all of it. I have also found a 72 2x4 with rust free bed,fenders,hood, and the cab only has half dollar size rust hole in one rocker. its still on the frame and has disc brakes,the guy is asking 650 for it all. this seems like good price, or am i showing my rookie by thinking thats good price?
