Old 06-25-2011, 12:47 PM   #1
handyhands
cleaning parts
I have the front suspension apart, I am going to clean and paint everything. What would be the best and cheapest way to do this? What would it cost to have the parts sand blasted?
handyhands is offline   Reply With Quote
Old 06-25-2011, 12:57 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: cleaning parts
If you have little rust, purple power, or super clean work great. I have a large tank that I put 50/50 purple power and water in it, Soak them over night, and all the gunk and paint are gone. Then just wash them off with a hose.
Sand blasting is not cheap to have done. You can but a set up at harbor freight, and do small parts yourself (if you have a compressor). Just make sure you wear a GOOD mask and other protection.
Dunenutt is offline   Reply With Quote
Old 06-25-2011, 04:12 PM   #3
nikwho
nikwho's Avatar
Re: cleaning parts
for cheap, I agree with above. Wire wheel to knock big stuff off, then purple power, rinse off and rustoleum rattle can. For longer lasting results you could have them all sand blasted and powder coated.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 06-25-2011, 04:41 PM   #4
mbgmike
Re: cleaning parts
For suspension parts sandblasting is not too expensive. We have a company that does ours. they are a large industrial blaster and do them for around 50 or less depends on the mood sometimes no charge just soft drinks. Of course we are in an industrial area where its common.
mbgmike is offline   Reply With Quote
Old 06-26-2011, 09:54 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: cleaning parts
I use the cheap dollar store oven cleaner.
Spray it on, let sit awhile, hose it off. Some areas might take two tries, but it's very cheap and easy.
Old 06-27-2011, 11:49 AM   #6
01spirit750
Re: cleaning parts
This is what I do. The dollar store near my house carries name brand oven cleaner. I suggest using latex gloves as it can sting the skin a bit.
01spirit750 is offline   Reply With Quote
