![]() Join Date: Jun 2011
Engine block vin
I am new to the trucks i have a 70 c10 with a 350 engine is the vin stamped by the oil filter like the cars ? If not where do i need to look ? Also what about the th 350 transmission is there a vin stamped on it also ?
Moderator
![]() Join Date: May 2007
Re: Engine block vin
No VIN on truck engines. There is a code stamped into the block, just in front of the passenger side head. If you are trying to see if the engine is original to the truck, the only way is if you have the original build sheet or protecto plate that will have the engine code listed on it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Master Procrastinator
there is also a stamp on the back below the drivers head you can see with a mirror without removing anything if I remember correctly and then it's easy to find the origin on here
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
Old Skool Club
![]() Join Date: Jun 2001
There are lists of engine codes (LMC truck has one in their catalog) that will at least tell you if the identifying letter codes at the end of the ID, are applicable to your particular (year/model) truck.
In my case, the last two letters indicated it was in the same year/model as my truck. I don't have the build sheet, nor the Protect-O-Plate for my truck, but I'm satisfied that my block is the one my truck came with from the git-go.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
well then i would think mine is the original my truck was built 02 /70 and the build date stamped on the block is VO217TAY
Code TAY= 70 350 Truck 255 LS-9 TH 350 4-Brl C 10 & C 20, 4X4
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 06-25-2011 at 01:29 PM. |
anyone have a decoder much like the vin: or what am i looking for 72 chevy 350 auto 4x2 ext
thanks |
#8 | ||
"I ain't nobody, dork."
There is a VIN decoder in the front of every LMC catalog.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
for the engine block vin? darn, i don't think i have a lmc catalog layin aroundh .
trying to match truck to motor .. thanks nate |
The engine block vin is called the block casting number. To decode your block casting number try here.
http://www.chevymania.com/ Click on parts ID, and then blocks.
CHEVY/GMC VIN DECODERS |
