Old 06-25-2011, 03:48 PM   #1
67Step
67Step's Avatar
Need Opinion on Motor Problem
I picked up an 88 shortbed for my daughter's boyfriend. It seemed to run fine when we put it on the trailer. We got it home and found it was completely out of water. I started the truck and put water in it. I then noticed steam coming out of the exhaust pipes. We now have milky oil in the crankcase. Motor is still running good. The truck had sit a while. Do you think it just needs a head gasket or ??? It starts right up and runs good. It is putting out steam from the exhaust like it was 20 degrees outside. Your opinions please? Thanks in advance.
1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1.
http://67-72chevytrucks.com/vboard/s...d.php?t=264458
1956 Chevy 3100 4x4 Stepside Truck. Sitting on Tahoe frame with LS motor.
67Step is offline   Reply With Quote
Old 06-25-2011, 04:26 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Need Opinion on Motor Problem
Blown head gasket, cracked head or block. Pull the heads, and check it out. Before you tear it down, I would get some cheap oil and change it. Run the motor a bit to flush out and then drain. Hopefully it is the water you put in it, and not some that has been there for a while.
Dunenutt is offline   Reply With Quote
Old 06-25-2011, 04:44 PM   #3
67Step
67Step's Avatar
I might also add that we noticed water on the ground on the passenger side. It appears to be coming from the back of the motor. It was blowing it on the ground behind the front tire. Strange..........
Old 06-25-2011, 08:25 PM   #4
Kim57
Kim57's Avatar
Check the freeze plugs. They may be the cause of the water coming from the block to the ground.
You can do a compression check and if you have two adjacent cylinders that are low that may be where the problem is.
Kim
Kim57 is offline   Reply With Quote
Old 06-25-2011, 11:33 PM   #5
mountie
mountie's Avatar
Check the spark plugs....... consider the behind right-side tire coolant 'leak', sounds to be below the catch tank?.......check for milky color inside the valve cover, under the oil filler cap / PCV valve..... radiator water for oil contaminates? ( there is an easy test for coolant). I had a cracked head and the truck ran fine..... only sometimes a lot of steam came out of the tail pipe.
When I replaced the heads, I also changed the lifters / pushrods.
If, BIG IF,.... you change heads, make sure the intake manifold gaskets are done clean / carefully so no oil drips!!
Pray.....
mountie is offline   Reply With Quote
Old 06-26-2011, 12:10 AM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea that's what I would try. You might also check the freeze plugs out. That sucks but hopefully its just a head gasket. Either that or time for a motor rebuild.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-26-2011, 12:51 AM   #7
mountie
mountie's Avatar
Heads R&R.... $1,200..... Crate motor, 4-bolt mains (jobber price) $1,300.
Old 06-26-2011, 01:00 AM   #8
89chevsj
error 404
89chevsj's Avatar
i'd buy a spare motor if i could get it for 1300!!
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 06-26-2011, 01:25 AM   #9
mountie
mountie's Avatar
Believe it or not..... My 4-bolt main 350 was a crate motor I purchased through Pep Boys Auto Parts. It's not a "Pep Boys" part, it was just distributed through them. Warranty, etc. It had Vortec heads, and the carburetor configuration ( I don't know why, but that was the better choice)....
I got it at cost, through a friend who builds Corvettes. He knew the details. I did the swap at his race shop.
8-3 to 1 compression..... It's the correct ratio for a Pro-Charger Supercharger, which I'll put on some day.
Price of $1,300 engine nearly same as heads installed, but a couple days to install engine.
Old 06-26-2011, 03:13 AM   #10
89chevsj
error 404
89chevsj's Avatar
I really need to move... like out of this frozen hell hole. haha that engine would run about 2200-2700. plus shipping, another 4-500. nothins cheap up here.
'12 Kia optima
Old 06-26-2011, 12:28 PM   #11
mountie
mountie's Avatar
Maybe order it from the actual company that sells it ( San Francisco area), and then it's the shipping cost only that will be the issue?
Then use a friendly autoshop up there to formally order it at jobber cost.
PM me if you want the contact. I liked their personal service.
