Hell yeah!!!
T5 clutch question
I've gone thru alot of the threads but still need a little clarification. I'm installing a v6 t5 out of an s10 and got the clutch pack for said t5. Non world class by the way. Now, here's my question, do i have to switch out the whole clutch pack or can i just use the clutch( by that i mean the part with the spline input) i see that the mating part is alot smaller but is this doable? Reason i ask is cause the pressure plate bolt holes don't line up to the ones on the flywheel. Help!
Stock is good but custom is the sh*t! |
Re: T5 clutch question
I used a astro van clutch,,,,plate is the correct size for our trucks flywheel/pressure plate
it is an 11" clutch disc that you need from an astro van. you should be able to order it separately, without having to order what they call a clutch assy kit, which is everything.
if the partsperson has any smarts they should be able to find one alone ron |
Like halfcocked said, use the astro van disc its 14 spline and 10 inch dia napa part number rcf4301 or 11 inch dia 14 spline napa number rcf4212.
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
Hell yeah!!!
Thanx guys, napa here i come.
sorry i dont have any input, but im curious as to whether or not you need to manufacture a tranny cross member and resize the shaft for this application
Hell yeah!!!
I'll be adding a crossmember to it. I had my trans built as a v6 camaro trans with the 1 inch 14 spline input shaft with a shortened retainer. Some people cut the end of the shaft but i measured my old trans and they're identical length, so i got lucky with mine.
Stock is good but custom is the sh*t! Last edited by nachodog2; 06-26-2011 at 01:13 AM. Reason: Misspelled word |
do you know what year s10 it was and what size your first gear is. i hear if the first gear is too low people have to take off from second. so you end up with four gears and a low. which is still better than my 3 speed
Hell yeah!!!
I went with an 87 non world class, as far as my first gear i'm not sure. I will ask my builder what gears he went with. I knew i should of got all that info.
if you have a tall rear end, i hear its not so bad. mine is a 4:11 so im gonna look for a t5 with i higher first gear, just for freeway driving. if your gonna pull something, ive read its better to keep the first gear lower. heres a link that might explain it a littler better. click on tech tips then click the t5 option. thank "jocko" for the link. he turned me onto it.
http://www.inliners.org/ |
where are you getting your tranny crossmember from? sorry for all the questions but im trying to get all my ducks in a row. tu sabes?
Hell yeah!!!
So what i have is a 3.76 first gear, and am running a 3.73 rear end. No towing or hauling for me, ripped the floor out when i did a 10 inch notch. I also have a 350 small block but i baby my truck, no john force burnouts on this one, just cruising down the highway and cruising down the boulevard. I'll check out the link, thanks jocko.
#13 |
Hell yeah!!!
Not sure, you can try looking it up here, but i'm gonna build my own.
#14 |
damn. you should be ready to go then. make sure to post some pics. i know im not the only one who could use em. good luck.
#15 |
Hell yeah!!!
How to install a Camaro T-5
Try a search with that heading, plenty of info, pics too. Posted via Mobile Device
#16 |
![]() Join Date: Oct 2009
nacho dog - I've got the exact same specs as your setup - 3.76 1st (although the tag decodes to 3.97 - but it is clearly a 3.76 when I measure it) and a 3.73 rear. I'm a little anxious that first gear won't be very useful. Also have 29"+ tall tires (which helps, but not a whole lot).
I agree with wc63. Am going into this eyes open, if I really just get a 4 speed with an 0/d 4th gear, Im ok with that. But I'm also considering having a taller (lower numerical) first gear into the trans before I install it - i.e. the gear from a camaro v8 trans - it's 2.something or other. Is yours already installed? If so, I'd really like to hear your impression on your 1st gear and whether or not the 3.76/3.73 combo is driveable/useful in 1st gear or if you're starting off in 2nd. Thanks - and nice truck! jocko Last edited by jocko; 06-26-2011 at 11:52 AM. |
#17 |
Hell yeah!!!
Thanx jocko, it's going in by wednesday. I needed a little clarification as to whether i could use my old pressure plate with the new clutch. Once this is done i will post my findings.
#18 |
Great, thanks Nachodog, looking fwd to it!
#19 |
Hell yeah!!!
So, after talking to my trans guy i am still confused. Here is the question, can i use my original pressure plate with a new astro van 11 inch clutch?
#20 |
I have already said it once before that is what you need, and just as long as your pressure plate is 11".
what is your trans man,; a true mechanic or a b/y'r ron |
#21 |
Hell yeah!!!
I'll check on that pressure plate padre. As far as the trans guy, he's an idiot, he just told me that they ( by they i don't know who ) no longer make the 11 inch clutch. He ended up being the male receptionist. I spoke to the actual builder and he said the same as you. At least they're gonna refund me the money on the 9 in clutch they had sold me.
#22 |
#23 |
#24 |
not sure if you know, I have heard this from others and it has happened to me, make sure that you are above 55mph when in 5th gear. Cause in my 37 chevy pu I was cruzing along at 55 or 60 mph and had to slow down below 55 cause of someone ahead of me and stayed in 5th, gave it just a little gas and no more 5th gear. Never did take it apart to see why.
1964 long fleet bed large rear window (project)(sold) 1965 chevy short fleet large rear window bagged (project)(thinking crew cab) 1965 chevy short fleet (driver/worktruck) 1937 chevy fenderless pu (use to be daily driver) 1983 MB turbo diesel (daily) |
#25 |
Hell yeah!!!
Been working alot this week with overtime and all but....it's goin in tomorrow and still need to get a new driveshaft, so it's gonna take a little longer. Sorry.
