Old 06-25-2011, 08:20 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
73 front end conversion
Here is what I know I need to convert my 85 to a 73 front end:
73-79 Core Support
73-74 outer and center grill supports
lower grill valance(metal filler piece)
headlight trim
Headlights & buckets
Parking lights
fenders
hood
73-79 f/r bumpers
What exactly do I need to do to the windshield wipers?
I don't need to worry about the hood hinges/latch bc I will have a fiberglass lift-off hood.
I have read and researched it but can't seem to find the info for the wipers.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-25-2011, 08:32 PM   #2
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Re: 73 front end conversion
You will need the wiper arms/linkage and nubs where the actual wiper attaches just above the cowl. The 81-87's are to tall and will hit the hood. When I did mine the guys at the salvage yard called it the wiper transmission. Hope that helps!
Grande Rojo is offline   Reply With Quote
Old 06-28-2011, 06:09 AM   #3
softballnrd27
Do I need to get a 73-79 wiper motor as well or will the one from the 85 work?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-28-2011, 09:23 AM   #4
Jonboy
Slots go on anything!
I think the one you have will work. You may want to keep it to make sure it plugs in correctly.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-28-2011, 11:54 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If you have the internal release, your going to need a few more pieces. You will need the core support filler panel, external release hood latch, and external release strike pin.Take a look in my sig for the details.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-28-2011, 12:07 PM   #6
softballnrd27
I will have a lift off fiberglass hood.
I read that post just about everday, well not so much as read as drool over your truck. Your truck is the reason for converting to the older style front end.
This is how I want to paint mine though:
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-28-2011, 09:42 PM   #7
superwade57
which of these core tops is inside release and which is outside release?
superwade57 is offline   Reply With Quote
Old 06-28-2011, 10:02 PM   #8
superwade57
im also swapping from an 86 to a 73-74 the frame horns are different for front bumber mounting, the inner fenders are different, i believe to be detail correct the the headlight bezels have a black trim paint in some spots and know that the turn signal lenses are actually amber colored and ive been told the body mounts need to be relocated? the very front ones that the core support bolts to can anyone confirm or deny that? and if so how far and in what direction? (sorry to hijack the thread)
Old 06-28-2011, 10:09 PM   #9
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
The top is outside.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 06-28-2011, 10:26 PM   #10
superwade57
Thank you
