06-25-2011, 09:22 PM | #1 |
Edelbrock Fuel Line Question
I'm planning to switch to an all metal fuel line from pump to carb (Edelbrock Performer Series 1406) with an Edelbrock 8131 Chrome Fuel Line kit. I noticed that the description on Amazon noted: "Does not work with OEM (Original Equipment Manufacturer) fuel pumps." I have a stock fuel pump. Is that really ture? I didn't think so but figured I'd better ask you all. Aslo, do any of you use or have an opinion on using a fuel pressure regulator (e.g. Spectre 2517) with that?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 06-25-2011 at 09:31 PM. |
06-26-2011, 09:03 PM | #2 |
Re: Edelbrock Fuel Line Question
You will need to make a new steel line from pump to filter and use a 6 an fitting to connect to the filter
Fuzzy |
06-27-2011, 12:27 AM | #3 |
Check, will do. Thanks,
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
06-27-2011, 10:00 AM | #4 |
And find a better fuel regulator. Those aren't the best. Cheaply built.
