love my truck
2.5 drop spindels and 2 drop coils 275/60/15 tires?
I am instaling in the next 2-3 weeks a 2.5 inch drop spindels on my 68 gmc. I already have 2 inch drop front springs. Total drop in front will be 4.5 inch drop. I am running 275/60/15 tires on 8" rims. Will I have any rubbing problems, if yes what the best solution?
Like a Rock!
do you have any pics of your current setup?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Out of the carpool lane.
Depends on your backspacing, but probably no problems. I have some Weld Rodlite wheels with 3 1/2" backspacing I think, and only rub and speed bumps and the like.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
THE QUICKER FIXERUPER
I just lowerd my 69 GMC panel 4.5 in the front with the same setup and 255 70's on 7'' rims tonight I should be able to drive it I dont think it will rub well see but it looks awsome.
Yes I think you may. I have only the 2 1/2 drop spindels with 275 60 R15 tires and they on a bump would rub. Recently as I have taken the truck apart I didnt have any rubber core support bushings they were gone. this should raise the front sheet metal some CORRECT??? Mine would rub on one of the inner fender bolts on a dip/bump at highway speeds. I dont have it back together yet to see if my height is corrected.
Good luck
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
You guys need to post pic's if you can...
I'm trying to decide "How Low to Go"
![]() 350/350 3.73 Next; 335hp GM Crate |
love my truck
c10crazy, heres a pic that you wanted. On this pic I have 2" in drop in front, 3"drop in back with 275/60/15.
Nothing fits but the oil
Here is my 71 GMC with 275/60's all the way around. They are mounted on 15x10 street stars, aboslutely no problem with clearances.
Land of the free Because of the brave |
Oh yeah, I forgot...3" drop spindles front, 4" coil drop in the rear.
And one more, the 10's are back spaced 4 1/2" hope that helps.
I finally got mine out of the garage today im hoping to drive it tomorrow I just need to blead the brakes onfe more time. The major setback was on saturday when I couldent get the truck to move I thought the brakes were locked up but realized that the wheels were smashed aginst the calipers (remember this and tell a friend 6-lug drum brake wheels wont fit over disc brakes!!!) sunday i found 5 rally wheels with GMC center caps for $200.00 they look great ill try to post pics.
