Front End torque Spec's
I am down to the bare frame on my 68 c-10. I have the crossmember off and on the floor. Along with all the control arms off and the control shafts out.
I am looking for all the torque specs for all the front end. For sure the control arm shafts upper and lowers . I'm going to paint the frame tomorrow so I have some time before I start putting it back together. thanks |
Re: Front End torque Spec's
Interested also
1969 Chevy c20(Miss Hackjob) |
1969 Custom 30 wrecker
Would love to find torque specs for all components myself. Maybe there is a list somewhere? I'm putting the Custom 30 wrecker back together and things like the brake backing plates, leaf spring bolts, etc. It would be great to know how much torque to apply.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
factory service manual has many pages filled with loads of important info like that
available cheap in high quality repinted form from most of the vendors on here
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Although an assembly manual can be the be-all-end-all of torque specs, the particular bolt is the application in question. If you know the bolt size you can look up the torque spec of that particular bolt.
http://www.imperialsupplies.com/pdf/...rqueCharts.pdf I applaud you for being concerned with this. It's a rarity.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! Last edited by BMERDOC; 06-26-2011 at 04:18 PM. |
Haynes doesn't have any torque specs for the control shafts, at least from what i could find in my book.
GM factory is the proper one for complete info
Restoration Virgin!
I've looked in a couple web sites with no luck....so ttt for ya.....maybe someone has the info.....I can say that we just did these on our 71 Super project, and since they were steel bushings, we tightened them up using a cheater bar and alot of muscle
I'll look at my books when I get a chance an see if there in there
I'm in a generous mood right now. Now go out and get the factory service manual if you don't have it!
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
#12 | |
![]() Join Date: Feb 2011
Can anyone clarify? Thanks!
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
#13 |
Restoration Virgin!
Thanks for your generosity....member's like you make it worth while for guys in a pinch......and YES...I agree....a factory assembly manual is a great one to have for the build as well!!!
#14 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#15 | |
![]() ![]() Posted via Mobile Device
#16 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I'll add this....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#17 |
I'm well into a full resto on my '69 big block C10 fleetside shorty and at the upper and lower control arm installation. As I understand the new upper control arm bushes torque spec is 160 ft lbs and the new lower bushes are 280 ft lbs. Can someone let me know the procedure for torquing them up, do I tighten them up while the truck is on the ground at static ride height or can they be tightened up on the stands, do I run the bushes in evenly from both sides or can they be tightened individually without damage?, tried looking for info on the install procedure but to no avail. If my torque specs are wrong can someone correct me. I have a manual ordered but it could be a few weeks before it gets to me in Australia.
Cheers truckers. |
