Old 06-25-2011, 11:07 PM   #1
68short
68short's Avatar
LS swap mounts with Thorleys????
Im getting some thorley tri-y's 324y-c, and they list with CCP mounts. Do you know off hand if this is a typo, and they mean CPP
Exhaust Header; Tri-Y Header; Silver Ceramic Coating; For Use w/GM LS1 Swap; C10 w/ CCP Mounts
68short is offline   Reply With Quote
Old 06-25-2011, 11:12 PM   #2
rob32472
Re: LS swap mounts with Thorleys????
There may be different versions but my thorley's worked great with ece mounts
rob32472 is offline   Reply With Quote
Old 06-25-2011, 11:16 PM   #3
68short
68short's Avatar
More options are good.......Thanks
Old 06-25-2011, 11:40 PM   #4
68short
68short's Avatar
ECE mounts says.....(Slight frame modification may be required, depending on application).
Were there any mods needed rob32472 ?
Old 06-26-2011, 08:01 AM   #5
rob32472
had to drill one hole in each side
