Parting 72 1/2 ton 2wd long bed
Just in is a 72 long bed that has bad sheet metal and the grille and frame horn are bent up. I will be using the bed, but the rest is being sold. Please respond in thread to avoid confusion.
Thanks, Ray core 350 motor- $150 local SOLD core th350- $50 local 5 lug front disc brake setup- $150 local 5 lug coil spring rear end complete drum-drum- $300 local SOLD 5 lug steel wheels- $100 plus shipping alt brackets- $40 shipped SOLD power steering brackets- $40 shipped SOLD crank/water pump pulleys- $31 shipped SOLD power brake booster, mc, prop valve, brackets- $60 plus shipping rams horn exhaust- $60 pr. plus shipping gauge cluster (bezel has holes drilled in it)- $25 plus shipping AT steering column- $60 plus shipping SOLD grille emblem with cracks- $10 shipped SOLD radiator support- $80 plus shipping gas pedal assembly- $40shipped outside heater box- $40 plus shipping black visors- $25 plus shipping bench seat needs cover- $50 local black seat belts (no center)- $36 shipped SOLD small block engine stands- $20 shipped black door panels driver condition- $40 plus shipping window regulators- $15 each plus shipping inside door handle guts- $15 plus shipping black vent windows- $30 pr. plus shipping AT shift linkage complete column to trans- $30 plus shipping 1 1/16 sway bar with frame brackets- $30 plus shipping 1/2 ton trailing arms- $50 plus shipping cab patches- $25 and up plus shipping frame pieces- $25 and up plus shipping Last edited by KrazyRay; 08-18-2011 at 11:05 AM. |
Just like to part out trucks!!
Re: Parting 72 1/2 ton 2wd long bed
Interested in the seat belts Ray, Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
pics
more
Randy, I will pull the belts and get pics.
Thanks, Ray |
If they glove box insert is still present, then what shape is it in?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Interested in the pull handle for the passenger side kick panel vent. All I need is the handle, rod, and knob. I have the door and seal already. Need it shipped to 28678
![]() Join Date: Nov 2007
KrazyRay,
How much for dome lamp shipped to 95380 ?
72 C20 Longbed 05 1500 Z71 |
Ray, I would like the altenator and power steering brackets to 24078 if they are still available.
Thanks, James
![]() ![]() ![]() 1970 Chevy C10 LWB 307 3OTT 3.73 gear |
![]() Join Date: Mar 2010
how much for the pan hard bar bracket (tracking bar on driver side frame) to 47274
Sorry, I had to run out and get another truck. I will have answers late tonight.
Thanks, Ray |
Thats the fun part Ray, going out and getting them
#13 |
Randy, The female part of the belt is cracked and broken. I can check my parts stash on Wed. to see if I can complete the set for you. Its really fun when you pick up a front end wreck short bed with a cherry bed!
Big Red76, Sorry, the insert is junk. cjohnson6772, $20 shipped for the kick panel pieces. sleepertruck72, $16 shipped if it comes out unbroken. James, $70 shipped total for both bracket sets. mater63, The bracket is in bad shape. I wouldn't run it on my truck. Thanks, Ray |
#14 |
Thanks Ray, pm sent
James
#15 |
Ok. I think I know of a truck local that I am going to check. I will get back with you if I wind up needing it.
#16 |
Restoration Virgin!
ray...is that a black auto column? Is it tight? How's the steering wheel? what's shipping to 28031? Thanks
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#17 |
Ray,
Sounds good. I'll take it if it stays unbroken.
#18 |
James- pm returned.
cjohnson- no problem. Geoff- Its a black column, it feels tight. $85 shipped. The wheel is badly cracked. sleepertruck- I will know Tues. Thanks, Ray |
#19 |
![]() Join Date: Feb 2008
is the fan shroud in good condition? no broken tabs or any issues?
if its G2G, how much and please quote to 79908. text 253-495-0880, thanks |
#20 |
This fan shroud is junk, however, I have a nice one with no broken tabs for $30 plus $17 shipping to TX.
Thanks, Ray |
#21 |
Hey Krazy,
If it's not too much to ask, text me a couple of good pics of that fan shroud. 253-495-0880, I'm needing one soon!! Thanks! Mondo Posted via Mobile Device |
#22 |
hOhows that inner grill, what youwant for it.? also yougot any chevy tailgates?, i dont mind a couple dings for the right price..
#23 |
sleepertruck- The dome lens came out ok, but the po had screwed the housing to the truck because the mounting tabs were broken. It works and does not show, but it is an imperfection.
Mondo- The shroud in the pics is the same as the ac one in my truck. JORGIE- The inner is broken at the driver side where it is pushed in. Sorry, no tailgates. Thanks, Ray |
#24 |
Restoration Virgin!
Ray...waiting to hear from my partner in crime on our 71 project to see if he has one yet or if I should pick this one up....he's visiting his family in a small town in MO so cell signal isn't the greatest
#25 | |
