HELP!!Electrical issues
I'm having problems with my turn signals/brake lights,when i touch the brake pedal the brake lights come on and the left front turn signal lights up outside and inside the dash,,without the brake on left turn signal in front blinks and both the rear signals blink.I have replaced the rear wiring harness,flasher switch,all the bulbs are new.What am i missing??Help me ,Please!!! Thanks in advance.
Re: HELP!!Electrical issues
Did it just start happening or has it done this since youve had it?
Just started last week.
Ground
I'll check tomorrow,Thanx!!!
#7 | |
When you say stays on do you mean all the time or just when something else is turned on???
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
As soon as you turn the ignition on,been messin around with it for a couple of days and decided to take apart the steering wheel,when i did this something must have been shorting out from the hazard switch,whenever i push in the hazards that left signal lights up on the dash,pull it out everything is working fine,i guess i kinda fixed it ???
