Kick panel vent question
On a factory air truck the passenger kick panel vent is operated via a vacuum canister. I have replaced my factory a/c unit with an aftermarket unit that no longer uses the vent for fresh air. I would like to convert the passenger vent to a pull handle arrangement like the driver side. I know trucks without factory air had pull handles on the passenger side too. My question is would I have to change the whole vent? Or can I remove the vacuum canister and spring and replace with a non-a/c style pull handle? Pics of non-a/c setups are appreciated as well. Just trying to figure out what all I need to change.
Old Skool Club
![]() Join Date: Jun 2001
Re: Kick panel vent question
Sounds like a good plan, to me. If your aftermarket AC unit doesn't need fresh air in the same way that the OEM AC needed/used it, I don't know of any reason why you shouldn't use a Non-AC vent door. I've seen them in the Brother's catalogs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Looks like if the door is the same all you need is the pull rod assembly. My 67 non a/c.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Sweet. That is what I was hoping. I don't wanna have to actually replace the door/seal. Just curious: is that the driver or passenger side? Are they the same?
I took a pic of the dr's side before I thought about it but looked over to the pass side. They are the same but side specific.
Perfect! Thanks for taking time to snap the pic!
Effortless on my part! Its Sunday and I've finished my chores. Watchin tv and clickin refresh every 15 minutes to see whats new!
Lol same here.
