Old 06-26-2011, 07:52 PM   #1
Blue Blood
Blue Blood's Avatar
What wheels are these? (vol.1)
I bought these today,I believe (based on the pics i'll post) that they're late 50's(1959?) kelsey hayes production wheels.
(1)They measure just over 16"-same as my current 15" wheels,so i'll assume they're 15".
(2) They're 6-5.5,so the pattern is good for my 62' c10.
(3)They're riveted.Does that mean i'll need to run tubes? If so,Is running radials a problem with these?
Thanks in advance...
The stamp on the wheel i'm pointing to says 7/59 -Kelsey Canada
Blue Blood is offline   Reply With Quote
Old 06-26-2011, 09:12 PM   #2
Max1775
Max1775's Avatar
Re: What wheels are these? (vol.1)
Don't know what kind they are, but you'll have to run tubes. Shouldn't be an issue with radials. I used to run a set the same way. I'm not a fan of riveted wheels due to the possibility of weakness issues.
Max1775 is offline   Reply With Quote
Old 06-26-2011, 09:18 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
should be 55-62?
pretty sure 47-54 had 6 tabs riveted on...
Old 06-26-2011, 09:24 PM   #4
Blue Blood
Blue Blood's Avatar
My understanding was GM went from the 'clip' style to the 3 'bump' style in 60'(maybe ?),then they went to 4 'bump' style...My issue is figuring out what exactly these are so that I can get correct-fitting center caps.
Hopefully someone here can set me straight on what these actually are..
Thanks guys.
Old 06-26-2011, 09:26 PM   #5
Blue Blood
Blue Blood's Avatar
Originally Posted by jonzcustomshop View Post
should be 55-62?
Cool,at least I have a starting point now!
I'm hoping I can fit a small passanger car style center cap on these with radials.
Old 06-26-2011, 10:25 PM   #6
7T2
Active Member
7T2's Avatar
Riveted wheels are usually the heavier-duty wheels. All the professional car (hearse and ambulance) chassis of the era got riveted wheels to support the extra weight of the car. If I'm not mistaken, riveted wheels are also spot-welded just like regular wheels, the rivets are an added measure to keep the wheel from coming apart.
If they were 5 lug they would probably be from a Cadillac commercial chassis, but since they are 6 lug they are almost certainly truck wheels. They take the hupcaps that look similar to this:
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-26-2011, 10:31 PM   #7
7T2
Active Member
7T2's Avatar
Also, before you get to far into buying hubcaps and mounting tires on them, test fit them to make sure the angled back of the wheel clears your brake drums and calipers. Those wheels usually mated up to brake drums that had an angled leading edge, and a lot of people find out the hard way that they won't work with more modern brake components.
1957 GMC Ambulance
1962 Belair Wagon
Old 06-27-2011, 04:25 AM   #8
Blue Blood
Blue Blood's Avatar
Will do,the guy I bought them from said he did put one on his 60' chevy lwb,& there wasn't an issue,but i'll definitely check myself 1st.
