Old 06-27-2011, 10:09 AM   #1
Caymandave
Dash Pads and Chrome door panel inserts
Hi All,
How hard is it to get the dash pad out and back in? 1979 Chevy C20. Also I am in the process of replacing the door panels and it seems that only one supplier "Classic Parts" supplies the chrome insert. Does that fit in LMC's OEM door panel?
Also if you are replacing the Instrument Bezel is that a bid deal or does it just unscrew?
Thanks in advance,
Dave
Caymandave is offline   Reply With Quote
Old 06-27-2011, 10:29 AM   #2
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: Dash Pads and Chrome door panel inserts
Dash pad comes out real easy.
Unscrew the 4 screws holding the lower bezel piece below the steering wheel
Remove the bezel by unscrewing it. It may be a little tight around the steering column, but is pretty easy to coax off.
Then remove the line of screws just above the glove box. Once all this stuff is off, pull the dash straight toward the rear of the truck to remove it.
I have the woodgrain inserts from Classic. They're nice quality for being plastic. I installed them on my OEM doors, but if LMC says their OEM panels will accept the original trim, then I think you're good to go. The trim around the woodgrain or chrome piece holds it together, not the insert.
sixshooter798 is offline   Reply With Quote
Old 06-27-2011, 10:36 AM   #3
Caymandave
Thanks a million.The big question was the clips how do they work in the dash pad and should I buy new ones?
My original door panels only have a chrome trim ring. Like I said I found a trim ring at Classic Parts but don't know if it fits LMC's door panels. LMC says you need to reuse the original, but it has lost its chrome finish and looks like plastic.
Guess I could ask.
Old 06-27-2011, 10:44 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
picture?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-27-2011, 12:49 PM   #5
Caymandave
Not sure I know how to post a picture to this site or any site.
How do you do that?
What I am talking about is on two different web sites.
LMV and Classic Parts.
Old 06-27-2011, 05:46 PM   #6
J Knight
J Knight's Avatar
If you cant get pics up, give us the year model and trim level of the panels you have. I'm going to guess you have 77-80 panels, if so lmc door panels accept original door trim. So if the trim you wrote about fit oe panels they will fit lmc panels.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-27-2011, 06:59 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
How do you do that?
I have both full catalogs here at my desk.
These the door panels you want?
1991 GMC Jimmy 4x4
Old 06-27-2011, 09:07 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Guess I could ask.
the dash pad clips lock on the bottom,there are spots that line up with these holes,for the clips and the pad slides down into place (if the pad looks uneven after one or two might be out)and then the screws need to go in place
up to you for new ones i bend them down for a tighter fit
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-28-2011, 04:02 AM   #9
sixshooter798
Desert Rat
Those look like Scottsdale trimmed panels. I'm guessing he is looking for Cheyenne/Silverado trim.
If it's like the one I've attached, your aftermarket trim should work on LMC oem style panels. Mine did.
Old 06-28-2011, 07:52 AM   #10
Caymandave
Wow Thanks a million. The trim ring which is shown in youi OEM panel I found at Antique Parts. LMC dudn't seem to have a trim ring.
Did you use the spray paint from LMC to paint the dash pad?
Thanks a million.
Old 06-28-2011, 12:36 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
well when he said classic parts had the trim ring, they only sell the scottsdale ring, not the silverado.
1991 GMC Jimmy 4x4
Old 06-29-2011, 03:25 PM   #12
Caymandave
I am sorry I did not get enough information on the site. I have a 1979 C=20 in has Bonnaza on the panel in the cab. I has Camper Special badging on the cab so the exact model is unkown.
