Replacing Steering Column Lower Bearings
I'd like to hear from someone that has done this. Is it a long drawn out job or relatively simple? The upper bearing is a snap but it didn't solve the grinding problem when the wheel is turned.
Re: Replacing Steering Column Lower Bearings
Odds are if the bottom is grinding it has ground down the shaft. Easy to replace after the shaft has been fixed. You will need to remove the column. Again easy to do, a few bolts a few wires. Hardest part is removing the steering wheel
