Air bags minus the pump for the rear? Complete Air noob here.
Is it even plausible to install a set of airbags just in the rear? I'm looking to bring the bed height down about 5 inches yet still be able to pump up the rear with an air tank when I have a load to haul.
Do air bags completely replace the rear coils? Or would I need a set of springs to put the bags into? What about the adjustable air shocks? Would I need a set of them as well or could I use a set of lowering springs and a set of air shocks to adjust ride height. Thanks guys! |
Re: Air bags minus the pump for the rear? Complete Air noob here.
You can do either way, run just rear bags and have full adjust ability and yes the bags replace the springs. Or you can run a lowered spring with a set of air shocks that you have to pump up when you have a load. I have a set of "helper air bags" on my Super duty for when I'm towing, not sure if anyone makes a set for the 67-72 though. mine are from firestone. Hope this helps.
Gotcha, so how do I find out what size bags will work? Do I need some kind of bracket kit?
So I can use just a set of lowering springs and inflate air shocks when I wanted to throw my bike in back and that would be enough support for the bed? |
If you just want to haul a dirt bike, I wouldn't even worry about.... I've got -6 springs in the rear with correct shocks and it works just fine. I wouldn't haul a load of firewood with it but that's because I have other trucks I would use for that.
Ok gotcha, so would KYB lowering shocks be considered good for that type of duty?
If I would have to eventually haul firewood would air shocks be the better route to go? Where can I get a good set of them and for how much roughly? |
Spend the money once & wisely..... Just swap in bags & skip the drop springs + 'air shocks'. Check the vendors Suspension Marketplace for suspension items from board supporting vendors. They have just what you seek.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-27-2011 at 03:59 PM. |
I have replaced the rear springs with air bags and can air them up to carry a load. If you consider 48 bundles of architectural shingles on a wooden pallet a load
#8 | |
Junior Member
Thats what im talkin about..... I got a good story about loading up a pallet of flagstone in my 1/2 ton too.... ha ha ha ha ha ha |
#9 | |
Thanks guys! Last edited by Low & Slow; 06-29-2011 at 08:20 AM. |
How low are you wanting to drop the truck? That affects how things need to be done correctly (& efficiently).
I was seriously considering a 3" spring drop up front and 5 in the rear. What bags would you guys suggest. Naturally, they would come from a vendor here.
Posted via Mobile Device |
we offer a rear kit which included the bags, mounts,hardware, shocks, lines, fittings and schrader valves for $450.00
#13 |
#14 |
this kit is a quality kit from Ridetech :-)
#15 |
#16 |
hmm. this gives me some ideas!
#17 |
Thanks to some stand up forum members and a vendor who answered all my questions I ordered a complete rear air bag setup for less than $200 shipped lastnight.
Thanks guys! Watch for pics. |
#18 |
#19 | |
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
#20 |
I'm considering going this route myself...
68 Chevy C-10. swb fleetside. 6.0 4L80E swap. http://67-72chevytrucks.com/vboard/s...d.php?t=460877 Last edited by 68chevyLQ4; 07-02-2011 at 08:13 PM. |
#21 | |||
http://www.67-72chevytrucks.com/vboa...d.php?t=450697 Here's how installs go. Other stuff that should be done as well.... http://www.67-72chevytrucks.com/vboa...d.php?t=129463 http://www.67-72chevytrucks.com/vboa...d.php?t=377272 http://www.67-72chevytrucks.com/vboa...d.php?t=195566 http://www.67-72chevytrucks.com/vboa...d.php?t=196457 For shocks.... http://www.67-72chevytrucks.com/vboa...d.php?t=437582 http://www.67-72chevytrucks.com/vboa...d.php?t=451200 http://www.67-72chevytrucks.com/vboa...d.php?t=452907 If you guys notice, most of this info was within our FAQ's section under the 'truck tech' icon.
#22 |
Thanks SCOTI!! mucho appreciated
68 Chevy C-10. swb fleetside. 6.0 4L80E swap. http://67-72chevytrucks.com/vboard/s...d.php?t=460877 |
#23 |
I can't edit my other info in the post from yesterday. Here's another link I thought I had included.....
http://67-72chevytrucks.com/vboard/s...d.php?t=442745
#24 |
Can someone please check the links provided above in post-21 to see if they work? They do for me but I was told they didn't by someone else.
#25 |
Junior Member
looks good to me
