tandem lock
I just bought a 1963 c-10 and it says "tandem lock" on the dash, what's this for?
Re: tandem lock
#3 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
http://www.davegrahamautoliterature....op_Manual.html
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Senior Enthusiast
Re: tandem lock
Other web posts indicate the Tandem Lock light is an indicator for a two speed rear axle found in C60-C80 trucks.
Re: tandem lock
i agree the gauge cluster came out of a larger tandem axle truck.there would be a switch on the dash (sometimes an air switch)to lock up the tandems,like 4 wheel drive if you will.highway tractors still have these switches today.helps you get out of some nasty situations,mud snow or even if you get hung up on a steep driveway incline or something and the front axle is off the ground and whheels are spinning inthe air,hit the switch and the rear axle locks in and away you go!
1961 crewcab
Re: tandem lock
the clusteer is probably original to the truck, on the smaller trucks the tandem lock and overspeed indicators just wern't lit up...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Oct 2009
Re: tandem lock
Concur with jonz - I believe all dash clusters were the same and you only got the switch, etc if you actually had a tandem truck.
Here's what I did with my tandem lock indicator... http://67-72chevytrucks.com/vboard/s...d.php?t=419932 Last edited by jocko; 06-27-2011 at 04:33 PM. |
Re: tandem lock
Thanks everyone. I know everything's original on my truck, it had set-up on blocks in a barn for over 30 years. I used to have a '66 and knew that it didn't have a tandem gauge on dash, so it surprised me when I saw that this '63 did have one. Do all '63 models have them on the dash?
Re: tandem lock
The tandem lock light came on small trucks with the factory gauge style clusters. Trucks that came from the factory with warning or "dummy" lights didn't have the tandem lock light option.
Re: tandem lock
Thanks for all the replies.
