06-27-2011, 03:52 PM | #1 |
transmission cooler location....ad pickup
i've been kickin the idea around of putting a transcooler in the passenger side inner fender ....behind the grill...has anyone done this ? any reasons this would be a bad idea ?....thanks..........whid
06-27-2011, 08:45 PM | #2 |
Re: transmission cooler location....ad pickup
Think of transcooler as a condensor or radiator, the more air flow the better to disspate heat. Transmissions cooler are used for this purpose, heat dissapation is the biggest concern on life expectancy of tranny. If the location has good air flow than put it there if obstructed mount mount a small fan on top.
06-27-2011, 09:22 PM | #3 |
i put mine under the pass side running board. but mine is an s10 frame swap too.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
06-27-2011, 09:26 PM | #4 |
My dad just mounted one in his Nova (limited space) right behind the radiator with some aluminum straps across the core support opening. It has good clearance all the way around and plenty of airflow from the puller fan. I'm going to try that location next time.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
06-27-2011, 10:36 PM | #5 |
When you say in the inner fender, do you mean cut a hole or just mount it in front of the inner fender behind the grille? If it's in front, I think you would have a lot of turbulence and not a lot of air flow there. If you cut a hole, that may work but I'd want some sort of gravel guard so the tire doesn't throw rocks at it.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-28-2011, 07:38 AM | #6 |
yeah,would cut a hole...had thought about some type of shield as well.........whid
06-29-2011, 09:35 PM | #7 |
We went with a finned cooler. The guys at TCI said it would work....lets hope so...lol.
http://67-72chevytrucks.com/vboard/s...206021&page=15 Post 363 Bernie |
