06-27-2011, 07:10 PM | #1 |
TH400 Leak question
OK, so my TH400 has started leaking. I have searched the threads and am a bit confused.
It is leaking out of the speedo housing (outside 90 degree box/mount on the side of the trans). I have seen a pic of the large o-ring that goes on the round section that the speedo box goes into on the case (ring is around 1 3/4" round). This doesn't appear to be where the leak is coming from. I am assuming there is an internal o-ring, but can't find a schematic that shows one for the 400. I have seen the pics of the "bullet" and o-ring for the TH350. Does the 400 have the same thing behind the speedo box or something different? Just wanted to make sure what I am dealing with before I pull the speedo box part out of the side of the trans. Thanks for the help.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
06-27-2011, 10:00 PM | #2 |
Re: TH400 Leak question
Check out Posts #14 and #15 in my Project thread and see if that is any help.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
06-27-2011, 10:49 PM | #3 |
Thanks for the link. Mine has an extra piece that screws into the trans plate and then the cable screws into it. Looking at your parts, it looks like I probably lost the gear seal.
Thanks again for the help.
06-28-2011, 09:42 AM | #4 | |
Glad to help. It's a pretty easy fix for what looks at first to be a big problem.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 06-28-2011 at 09:44 AM. |
