Old 06-27-2011, 08:53 PM   #1
gotchamel
fuel pump/fuel line ?
Looking into changing my pump to carb line out,current line is 5/16"steel{not 3/8"}and outlet on pump is too.Aren't most sbc fuel pumps 3/8"?Its a 69 307 4 barrel.
Thanks.
gotchamel is offline   Reply With Quote
Old 06-27-2011, 11:16 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: fuel pump/fuel line ?
I think many of the V-8 trucks had the 5/16" fuel line. I sure someone that knows more about it will chime in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-28-2011, 08:13 AM   #3
cdowns
cdowns's Avatar
i believe most V8 trucks had 3/8 and 6cyl trucks came with 5/16
Old 06-28-2011, 08:32 AM   #4
gotchamel
This truck had a V8 from the getgo but I am finding out the 5/16"is unusual.
Old 06-28-2011, 08:57 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your truck was probably a 2 bbl truck originally.
inline 250 got 5/16ths
I think 292 got 3/8 (I could be wrong on that)
All v6 trucks got 3/8
2 bbl small blocks got 5/16
4 bbl small blocks got 3/8
all big blocks got 3/8
Old 06-28-2011, 09:31 AM   #6
gotchamel
2 bbl makes sense,the vin showed a V8.I guess if I want to go to 3/8 I will need a fuel pump or atleast a bushing to step up the size.
Old 06-28-2011, 12:35 PM   #7
FLDBRED
I think with a 307 the 5/16 line would be fine!
FLDBRED is offline   Reply With Quote
Old 06-28-2011, 01:12 PM   #8
1stchevy
1stchevy's Avatar
I'm running 5/16 on a 350 with a 4 bbl and have not had any issues.
1stchevy is offline   Reply With Quote
Old 06-28-2011, 02:15 PM   #9
Longhorn Man
the reality is, you'd need to be holding your engine at 6000 RPM for a while to run the carb dry (assuming everything is right) with a 5/16ths line.
Old 06-28-2011, 09:16 PM   #10
gotchamel
Hearing truck fire stories I got buggered on rubber hose so I ordered a steel carb line and filter assembley{edelbrock}and a pump to filter line{steel}from LMC,all 3/8".My pump is 5/16",I'll either replace the pump or step up the outlet.I am not worried about lack of fuel,just plumbing it neat and safe.Thanks everyone.
Old 06-28-2011, 10:37 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
In that case, you can buy a pump for a 350 at the parts store for under 20 bucks and it will have the 3/8 fitting that your new line requires. It will of course fit your 307 directly. New fuel pumps are a nice piece of mind anyway for reliability's sake.
Old 07-15-2011, 05:30 PM   #12
gotchamel
Put a 3/8" fitting in the pump.I now have all new 3/8"from pump to carb with only a few inches of thick wall rubber fuel line for good fit.Thanks for the input.
Old 07-15-2011, 09:21 PM   #13
hayhauler71
hayhauler71's Avatar
have any completed pics of the fuel line project
Fuzzy
hayhauler71 is offline   Reply With Quote
tst
