Old 06-28-2011, 11:43 AM   #1
Low & Slow
I need the parking brake cable/ brackets/ adjusting bracket. Where to buy?
So fixing up the c10 I recently acquired and while inspection the rear which the previous owner swapped in I noticed that there were no rear parking brake cables going into the assemblies. Nor is the adjustment bracket under the bed.
I can find the cables online but I need the whole assembly. From mid cab back to the adjuster, all the way to each hub.
Any ideas guys? Can other year Chevy parking brake components be used? Are the adjusters basically the same assembly? Any problems buying these parts used?
Thanks!
Low & Slow is offline   Reply With Quote
Old 06-28-2011, 09:47 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: I need the parking brake cable/ brackets/ adjusting bracket. Where to buy?
to the boards Low & Slow from NC.....might want to look over in the parts forum...guys parting trucks over there could probably help ya out.....is your truck a long or short bed? (this will determine the intermediate cable needed)....also, if ya want new, ww.inlinetube.com has a setup, but it's pricey
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-28-2011, 10:51 PM   #3
Low & Slow
Thanks for the warm welcome sir!
Yes, it is a longbed. How do I go about locating the for sale section? Pardon my ignorance, brand new to trucks. In fact, brand new to anything older than 1988. It's been fun so far! Lots of surprises.......
The brand new master cylinder started weeping from the booster mating surface for some reason.
Old 06-28-2011, 11:01 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What year truck do you have? There's a difference in the '67-8's compared to the '69-72's.
Member Nr. 2770
Old 06-29-2011, 08:17 AM   #5
Low & Slow
it is a 67.
Spent hours last week in the local junkyard attempting to track down another 67-68. No luck.
Old 06-29-2011, 08:29 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
....sorry....I thought you may know where the parts forum is...if you're married, tell her it's my fault that I posted this....and beware....you'll spend HOURS in here looking for parts!!!! http://67-72chevytrucks.com/vboard/forumdisplay.php?f=8
Also, here's a diagram I like to post up for e-brake stuff...it's pretty helpful
As ChevloRay mentioned, the difference between 67/68 and 69-72 is that the 67-68 has a hand pulled ebrake, while the 69-72 has a foot operated ebrake...so the line exiting the firewall will be different locations....but after that it's pretty much the same for 67-72 (the areas highlighted in red)
Geoff with a G
Old 07-07-2011, 09:10 AM   #7
Low & Slow
So no luck with the marketplace. Any more ideas?
Year one would cost me something around $175 which is nuts. This is all I need to pass inspection I've managed to button up all the other issues.
Old 07-07-2011, 09:40 AM   #8
Call Inline Tube.Be prepared to speak to a gruff character. But,he can get you any piece involved. Every piece of hardware in OEM spec.
www.inlinetube.com
Old 07-07-2011, 09:48 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Call Wes at Classic Heartbeat in Wash. 888-338-2502 He knows his stuff, Hes a great guy and a vendor here on the board.
Tom Vogel is offline   Reply With Quote
Old 07-13-2011, 02:02 AM   #10
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I just installed a set of cables on my 68 but I had the hardware already. I bought mine off LMC I had a problem with a lot of play where the cable inserts into the rear backing plate(?) I used the small springy washer from the original cables on the outside and then right behind still on the out side I use a large flat washer to take up the slack and all is good i didnt pass inspection cause I hadnt replaced them yet, they were sitting on my floor for months
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-13-2011, 11:08 AM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My '68 cab doesn't have an ebrake handle. I have the one that was in my '69 cab, but it won't work without some sheet metal modification....and I can't do it.
So, for me (at least) it looks like Lokar is going to get a little bit more of my money...next time I go to take a dump.
Member Nr. 2770
Old 07-13-2011, 01:33 PM   #12
72lb4x4
Your local auto parts store, and/or rockauto.com should have the cables. Too many of us buy stuff from specialty vendors when the parts are readily available locally. Its part of the learning process.
There are a few guys that part trucks regularly that post in the parts areas. No doubt they'll have the hardware but there may not be specific for sale posts.
72lb4x4 is offline   Reply With Quote
Old 07-18-2011, 09:49 AM   #13
Low & Slow
Went into my local autozone looking for the rear diff seal with the intent of changing fluids. Ended up asking the clerk for the cables out of curisosity and they have them! $15 for each side. Plus $20 for mid cable. Only problem was that he had 3 sizes. SWB, LWB, and then a 133" wheel base.
Still need the brackets and all but Im assuming that with a 8' bed/ lwb I need the 127" cables right?
They had to be ordered but will be at the local store in a few days.
K.I.S.S.
Old 07-18-2011, 02:15 PM   #14
jaros44sr
jaros44sr's Avatar
did ya try shorty and daves auto salvage in norristown yet? seem to remember a few in there...
s'posed to be another yard up around quakertown or south of it, but haven't found it yet
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-18-2011, 04:04 PM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
correct...you'll need one for your lwb truck so 127" is right...just to be sure, if your SPID is still in the glovebox, it should have the wheelbase listed on the top right
Geoff with a G
Old 07-22-2011, 02:35 PM   #16
Low & Slow
So I went to pickup my cables at autozone today as they were a special order and I was told they would be in today. Got there on my lunch and was told they were actually discontinued by Wagner.
Crap. Back to square 1.
Ill try Shorty and Daves next I suppose.
Old 07-22-2011, 03:03 PM   #17
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Now why the heck didnt they call you and tell you that? That really burns my biscuits!
I got my stuff from Classic Parts, I did my e-brakes like a 66 cause the trans bracket was gone.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-22-2011, 08:18 PM   #18
jtp67-72
jtp67-72's Avatar
Low and slow--I have everything from brake handle back-off my 68 longbed-includes brake handle assembly-mid cable-cables out of rear-(need to look and may sure they are ok-just disassembled last week-will post pics in am---jim
jtp67-72 is offline   Reply With Quote
Old 07-26-2011, 10:57 AM   #19
Low & Slow
So I found the Intermediate and both rear hub cables for $42 shipped. Im just a little confused with what connectors I need. Is there a specific Y connector to join the rear hub cables to the intermediate?
Rockauto has the one to one cable connectors but nothing that would join the rear to the inter.
Ideas as to where to source this?
Thanks for all the help guys!
Old 07-26-2011, 12:41 PM   #20
gcburdic
Restoration Virgin!
gcburdic's Avatar
Look in my post #6 above....view A shows the part needed....again...I recommend asking someone who's parting a truck over in our parts forum....you'll need 2
better yet, you could become a member and post a want to buy (WTB) in the parts forum...it's the membership that keeps on giving and giving
Geoff with a G
Old 07-26-2011, 12:52 PM   #21
Low & Slow
Saw the diagram but was spittle confused. It looks like the hand brake cable is in white coming down out of the cab and then joins with the red hub cables. But what's that red cable that goes forward? That is throwing me off.
I have some feelers out right now with some members but most want more thn the cost of brand new.
Old 07-26-2011, 01:03 PM   #22
gcburdic
Restoration Virgin!
gcburdic's Avatar
once it comes out of the firewall, it connects to a solid rod that has a u type clip on it for adjustment....the intermediate cable is then routed to both rear brake cables (the u-shaped red cable) and connected by that clip in view A.....there is also a solid rod that supports the cable under the passenger side and connects to the frame...I believe this this is the red item that's confusing you, right?
Geoff with a G
Old 07-26-2011, 01:13 PM   #23
Low & Slow
Can you tell this is my first time doing a parking brake on a truck? Lol
I'm gonna need to go to the junkyard and take a ton of pics.
Old 05-21-2012, 02:13 AM   #24
CEE1NG_RED
There's no how to video on how to do this?? Mine is missing the cables and hardware the ties the front and rear cables together into one point. [sigh]
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 06-06-2012, 03:10 PM   #25
69CST4x4SWB
69CST4x4SWB's Avatar
Location: Oregon, The Beautiful Pacific Northwest (GOD'S country)
Could you post an update as to where you ended up getting everything and how it all went together for you. My '69 K10 SWB needs some work on the park brake assembly. I believe all the parts are there but it seems like the middle cable might be to long (not correct cable)! Someone jimmy rigged it with a long spring to take up the slack. Problem is, it only applies very little pressure to the brake, not enough to really hold it. Also, the foot pedal only returns about half way up... Broken or missing return spring? Any ideas? Sorry if I am not making much sense... been extremely sick over the last month! Thanks in advance.
In GOD I Trust All Others I Question!!!
1969 Chevy CST K/10 SWB (Legs)
1969 Chevy C/20 LWB (Old Gray Mare) Donor
1972 GMC 1500 Sierra Grande (Orange Creamsicle) Sold
1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold
1991 Chevy Silverado Ext Cab (LowBoy) Sold
2008 Harley Davidson Electra Glide (Black Betty)
Mark ~ US ARMY VETERAN 2nd ARMORED DIVISION 67th ARMOR
69CST4x4SWB is offline   Reply With Quote
