Old 06-28-2011, 02:19 PM   #1
doodah man
doodah man's Avatar
Question Got dipstick tube, but can't get it in
I got a OEM dipstick tube for my 350 SBC from a very generous board member recently, but I'm having a rough time trying to get it in the block. I gave up for fear I was going to break the end off the new one. Does anybody know a trick for getting these in? It goes in about 3/8" but I didn't get it further. I was gripping it with a pair of pliers just above the lip at the bottom and my nephew was tapping the pliers with a hammer.
It looks like there is a groove in the exhaust manifold (ram's horns) that the tube should rest against. Is that the correct placement or is that just a coincidence?
Here's what I'm working with:
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 06-28-2011, 02:30 PM   #2
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Re: Got dipstick tube, but can't get it in
We always clean them really well, dress them down just a bit with emery cloth and then freeze them. Helps a bunch..
specialtyretail is offline   Reply With Quote
Old 06-28-2011, 02:36 PM   #3
yuccales
yuccales's Avatar
Yes, it goes into the groove on the manifold.
yuccales is offline   Reply With Quote
Old 06-28-2011, 02:58 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
great idea...especially freezing as the metal will slightly shrink...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-28-2011, 04:21 PM   #5
tooter
tooter's Avatar
Are you sure none of the old tube is broke off in block??
tooter is offline   Reply With Quote
Old 06-28-2011, 04:55 PM   #6
specialtyretail
I was thinking that also...
Old 06-28-2011, 05:20 PM   #7
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
x3
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-28-2011, 07:18 PM   #8
Frkypunk70
Frkypunk70's Avatar
If you have all that broke off inside out. Then I would try that freezer trick, I've seen it work on bearings and bushings( never thought about it on a dipstick) Good piece of advice. Also clean any paint off where it goes into the block and put a little anti seize and or lubricant on there. They are definetely a tight fit normally. Let us know what works for ya good luck.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 06-28-2011, 08:05 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I run them across the bench grinder and wire wheel to remove any paint, grease, or burrs. Then tighten a crescent wrench down to where it fits the tube snugly right up against the bulged area then hammer it in with a hammer on the crescent wrench.
Old 06-28-2011, 08:34 PM   #10
68 IRON
68 IRON's Avatar
Not to hi-jack......but this should work the other way also, right? Freeze the base, vise grips around tube with a drill bit in the end...and/or wiggling the tube out?
68 IRON is offline   Reply With Quote
Old 06-28-2011, 08:39 PM   #11
Autoblueprint
Autoblueprint's Avatar
Lightbulb Re: Got dipstick tube, but can't get it in
These dipstick tubes are an interference fit...(1) attach a crowfoot of the correct size ( so that the crowfoot won't slip past the tube "dimple" ) to a long ( 36" or so ) 3/8 ratchet extension (2) then align the tube for proper dipstick pull position (3) then tap the top of the extension with a brass hammer till the tube dimple bottoms in the block.
Of course, make sure there is no broken piece in the dipstick hole in the block before doing this. Also, to prevent oil seepage, you may want to put some non-hardning sealer on the dipstick shaft that goes into the block prior to driving it in.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 06-28-2011, 08:42 PM   #12
Autoblueprint
Post Re: Got dipstick tube, but can't get it in
Should work...it is the same principal as the crowsfoot.
John Harlowe
Old 06-29-2011, 07:16 AM   #13
doodah man
doodah man's Avatar
Thanks guys. I'll try the freezing trick this weekend. I did get the broken piece out (after about 30 minutes of pulling and pushing and cussing).
1972 C-10 Deluxe
350 V8 - 350TH
