Old 06-28-2011, 04:17 PM   #1
dchough
700r4 problems. 6.2 Diesel
Hey everyone.
Thanks a lot for helping me with my last problem. I replaced the lift pump like you all said, primed the system, and my '82 6.2 fired right up. You guys on dieseplace and here on 67-73chevytrucks are awesome!
Now onto another problem... My 700r4 shifts REALLY late.
1-2 **** occurs at 30 MPH on the dot every single time. The 2-3 shift occurs at 43 mph every time. I have never had a 3-4 shift, even at 65 on the highway. Letting up on the throttle DOES NOT produce an up shift. The 1-2 shift is also very hard -it jolts into 2nd. Less so with the 2-3 shift. Once the shift is made, stomping on the pedal DOES NOT produce a downshift.
The tranny fluid is a nice red. Doesn't smell new, but doesn't smell burnt either. It might be a little low, but should not be enough to cause such problems (or at least I think )
I have searched for weeks on this problem and I have narrowed it down to:
1. A bad TV Cable
2. Stuck valve
3. Bad governor
The 1-2 shift at 30 mph would mean its shifting at full line pressure, right? I feel like simply loosening or tightening a cable couldn't fix the shifts when they are EXTREMELY late, or could it? Am I looking at probably replacing the TV cable as opposed to adjusting it?
Also, what the hell is a stuck valve? It involves dropping the pan and cleaning the insides, right? Wouldn't a stuck valve produce more irregular shifting? the 1-2 shift comes every single time at 30 MPH.
Lastly, I read once that if there is a pin or ball or something that goes bad, the 700r4 has a automatic device that will send the tranny into "late shifting mode." Any thoughts? What would cause this?
Pretty much, what do you guys think is the cause of my shifting problem, given my symptoms?
Thanks a lot more looking out for me and reading this ridiculously long post!
-Dereck
dchough is offline   Reply With Quote
Old 06-28-2011, 05:24 PM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: 700r4 problems. 6.2 Diesel
Originally Posted by dchough View Post
Hey everyone.
Can we say "I told you so"? In a good way though.
I hate to bring up a stupid question... but are you positive you have a 700r4 and not a TH400?
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-28-2011, 05:32 PM   #3
MadManAndrew
Guy at Napa asked me that yesterday, "Are you sure you have a 350? You know, they put turbo 400's in these trucks too." I just looked up and stared at him until he went back to searching, lol.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 06-28-2011, 07:03 PM   #4
dchough
OH MY LORD.
I bought this truck 3 weeks ago. Probably spent an hour checking it. Thought it was a 700r4 right off the bat. Even looked at the oil pan...
lindstromjd, when you asked that question, I thinking in my head, what a silly question, of course its a 700r4. The gear indicator panel even says "overdrive" indicative of a 700r4 4 speed tranny. I could have sworn i looked at the tranny pan and seen the rectangular pan, but when I went outside to check the oil pan shape again, just to be sure... sure enough its a th400. Someone must have replaced the 700r4 with a th400 at sometime.
Hahahahahaha. I am a moron. For the last 4 weeks I have been spending hours a day google "700r4 shifts late and hard."
I don't know whether to laugh or cry.
Having sorted through that MINOR detail, I still feel like the shifts are still late. Sounds like the engine is working wayyy to hard on the 1-2 shift and it still kicks.
Any ideas? Jeeezzz. Hahahaha I am a complete idiot.
Old 06-28-2011, 07:31 PM   #5
lindstromjd
Ok... No hard feelings. I'm going to say that you're probably not getting enough vacuum to the modulator on the back of the transmission with that late of shifts. I wouldn't worry about the hard shifting; that's usually indicative of a shift kit. Slow, soft shifting and taking forever to grab the gear is a problem.
So... where are you getting vacuum from for the transmission? From the vacuum pump of the back where a gasser distributor would go? Or from the side of the injection pump? I'd almost say that with that late of shifts, and the no downshifting, you might not have any vacuum to it at all, and it's acting like you're going balls-out, wide open throttle at all times.
-357 / 700r4
-350 / TH350
Old 06-28-2011, 07:45 PM   #6
dchough
I think you are right. I don't have any vacuum. I wonder if any adjustments are needed to be made when switching from a 700r4 to a 400th behind a 6.2, like the vacuum. The 700r4 doesn't have a vacuum modulator line right? I wonder if the previous owner just dropped in a th400 without making the necessary changes to make it compatible. The guy I bought it from said it has shift late ever since he had it.
What do you think? I can take pictures of the setup and post them. Maybe you can spot something I can't?
-Dereck
Old 06-28-2011, 07:49 PM   #7
lindstromjd
I'll do what I can.
I actually did the opposite swap in my truck, so I know what it needs to run with both transmissions. I used to have a TH350, and have a 700r4 now. The 700r4 uses a TV cable to control the internals, and the TH350 and TH400 use vacuum modulators and a kickdown cable.
Let me see what the vacuum pump on the back of the engine has going to it, and the passenger side of the injection pump. And there should be a vacuum line going to the very back end of the transmission; mine used to be a steel line with rubber hose on each end.
-357 / 700r4
-350 / TH350
Old 06-28-2011, 09:06 PM   #8
rcbildr
rcbildr's Avatar
On the injector pump there is supposed to be a vacuum regulator valve. It's in the same spot the Throttle Position Switch for a 700R4 would be. It's job is to mimic/replicate the change in vacuum that occurs in a gasoline engine when you go to accelerate. You will need to buy a vacuum gage to check this. Here is where my memory is a little rusty. Find the hose that goes down to your transmission and unplug it from the valve...hook up your vacuum gage to that port. Now for the rusty part of my memory. IIRC I adjusted mine so it was reading around 14" of vacuum. The adjustment is not the 3 screws holding it to the injector pump...they might have a role in that but I never got a clear answer on that. There is a nut going around the fittings that you turn...it might be a little difficult to break free. It is adjusted close when you see the vacuum drop as you rev the engine. IIRC the drop should be proportionate to how high you rev the engine. I think there might be more to it than that, but I've have a hard time finding the info.
The gage will also tell you if you vacuum pump is working...another way to tell is if you have a/c and your controls work.
IF you have no downshifts, the kickdown switch might not be hooked up too.
If you don't have a vacuum regulator valve, they can be hard to find. I managed to locate one a while back for around $100. I got mine to work sop I didn't have to buy that one.
Hope this helps.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-28-2011, 09:39 PM   #9
hatzie
Moderator
hatzie's Avatar
I'll do what I can.
The TH400 uses a kickdown switch inside the cab on the accelerator pedal. The 700R4 and TH350 have the cable...
Old 06-28-2011, 10:06 PM   #10
dchough
Here are the picks. Pretty hard to see and maybe not what you want, but maybe something here can tell you? Hahaha as you can tell I am out of league on this one.
Could get the pictures on through the forum, but I have uploaded them on photobucket.
http://s1239.photobucket.com/albums/ff513/dchough/
So let me see if I understand this right. There is a vacuum modulator on the passenger side of the transmission. This tells the transmission what the engine is doing based on vacuum pressure, and thus directs the transmission to shift accordingly. So then a hose runs from the vacuum modulator directly up to the vacuum pump, and then from the vacuum pump to the injector pump, which is linked in some way to the throttle?
I probably have all that messed up.
But the cause of my late shifting would be because there is not enough vacuum at lower RPM's, thus it needs to run at WOT in order to activate the vacuum module to tell the tranny to shift? Is that even close to being right?
The fact that the tranny is still shifting is good though i assume? Would the tranny shift without any vacuum?
Old 06-28-2011, 10:12 PM   #11
MadManAndrew
Yes, the tranny will shift with or without vacuum, the vacuum just makes the tranny shift more accordingly to the motor than the standard shift points.
Old 06-28-2011, 11:57 PM   #12
rcbildr
rcbildr's Avatar
****So let me see if I understand this right. There is a vacuum modulator on the passenger side of the transmission. This tells the transmission what the engine is doing based on vacuum pressure, and thus directs the transmission to shift accordingly. So then a hose runs from the vacuum modulator directly up to the vacuum pump, and then from the vacuum pump to the injector pump, which is linked in some way to the throttle?*****
You have all the parts just not in the right order. Starting at the vacuum pump there is a hose that goes from the pump to the vacuum regulator valve (VRV) on the injector pump, then from the VRV there is a hose that goes down to the vacuum modulator.
In addition to being able to adjust the VRV you can also adjust the vacuum modulator too. I was able to on mine, I'm not sure if all TH-400's have and adjustable modulator. Inside the nipple on the modulator is an adjustment screw. All you need is a small flat tip screwdriver and IIRC when you turn the screw in it make the shifts later and firmer.
My Projects:
1978 Camaro Z28
Old 06-29-2011, 06:11 AM   #13
78maliburat
[QUOTE=MadManAndrew;4761498]Yes, the tranny will shift with or without vacuum, the vacuum just makes the tranny shift more accordingly to the motor than the standard shift points.[/QUOx-
THE GOVERNOR WILL SHIFT IT
78maliburat is offline   Reply With Quote
Old 06-29-2011, 11:54 AM   #14
spudz
spudz's Avatar
You probably don't have a diesel governor.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-29-2011, 12:56 PM   #15
dchough
Update:
I took the line from the Vacuum pump to the VRV off and determined that there is in fact vacuum suction. I could tell the line was actually oscillating and sucking in and out just by looking at it. So I can now check a bad vacuum pump off my list, right? Or perhaps its not enough suction?
So i am assuming the problem is somewhere between the inlet of VRV and the vac modulator. What are the chances the VRV itself isn't working? What should I look for? Something disconnected?
Also, what are the chances this shifting problem is indicative of a simple adjustment at the VRV or Vac modulator?
Thanks guys. I am learning a lot and really starting to get a feel for this system.
Old 06-29-2011, 06:53 PM   #16
rcbildr
rcbildr's Avatar
I think you are at the point to where you need a vacuum gage. Disconnect the hose on the VRV that goes to the modulator, hook up the vacuum gage on that port of the VRV, and then rev the engine and see how the gage reacts.
My Projects:
1978 Camaro Z28
Old 06-29-2011, 07:06 PM   #17
dchough
Alright, So I think I have narrowed down my search.
I ran a vacuum test on the vacuum pump from the line that goes to the VRV. After it warmed up a bit, I got the vacuum to run at 18". I replaced the cracked and worn hose from the vacuum pump with a brand new one, and that bumped the vacuum pump reading up to a steady 24" once it was warm. So I am assuming my vacuum pump is good.
Then I hooked up the gauge to the outlet port of the VRV (the line that goes to the transmission modulator). After about 15-20 seconds of the needle slowly rising, it stopped and stayed at 8".
So I am getting about 24" into the VRV and only 8". I tried adjusting the VRV, but the VRV is already as straight up as it goes. Any adjustment brought the outlet VRV suction down from 8" to about 6".
I also ran a vacuum test at the tranny modulator, which was 0". So i am getting no vacuum at the tranny module, which is probably the cause of my shifting woes. (Additionally, when I disconnected the line to the modulator, there wasn't any tranny fluid, so I am assuming the tranny modulator is ok.)
So I am assuming I need a new VRV? Does this sound right? Is there anything on the VRV that I can take out and replace or rebuild, or is it better just to replace the whole thing?
Thanks again!!!!
-Dereck
Old 06-29-2011, 09:50 PM   #18
rcbildr
rcbildr's Avatar
There is another adjustment on the VRV, I'll have to go look at mine again so I can describe what to look for/at...I'll post up when I do.
There isn't much to the VRV valve. I was able to take mine apart and clean it up to get it working again. You should see high vacuum at the VRV and then it will drop when you rev the engine.
I'll be able to go out and look at mine in a couple hours (I'm at work right now) and I'll let you know.
My Projects:
1978 Camaro Z28
Old 06-30-2011, 12:34 AM   #19
rcbildr
rcbildr's Avatar
Ok, let's see if I can describe this right. Looking at the top of the VRV you will see the 2 nipples for the hoses. IIRC the top hose comes from the vacuum pump and the bottom hose goes down to the modulator. Just below the lower nipple is a collar with 4 prongs 90* apart. You can twist that collar to adjust the amount of vacuum going to the modulator and it also affect how the vacuum drops off when you rev the engine....you will have to play around with it to see which direction to turn the collar. I hooked up the gage to the lower nipple and adjusted mine to about 14" of vacuum. If I remember right that was where the vacuum would drop off when I would rev the engine. The drop should be proportional to how high the engine is rev'd. It took me a while to get it right and at first the collar didn't want to turn. Hope this helps.
My Projects:
1978 Camaro Z28
Old 06-30-2011, 11:14 AM   #20
dchough
Hey,
Thanks for the description. I'll check that out and report back. So i twist all 4 prongs?
Old 06-30-2011, 02:06 PM   #21
dchough
RCbildr,
So i twisted that collar thing you were telling me about and IT WORKED! You were right, it was hard to twist, but once I cleaned it up and sprayed it with some PB Blast, I was about to get it moved. It was all the way down, screwed on tight to the bottom. I twisted it towards the top and I also unscrewed that pivot screw on the side of the VRV itself (not where it attatches on the IP) And I was able to get about 11" out of the VRV. I took it for a test drive and the 1-2 shift is at about 16-17 mph, and the 2-3 shift is at about 32-33. Still alittle high, but I am going to mess around with it.
Thanks again! And thanks to everyone for their help! You guys saved me over $100 for a new VRV!
Old 06-30-2011, 05:28 PM   #22
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
wow is that a true red block engine?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 06-30-2011, 10:18 PM   #23
dchough
Yup!!!
Old 07-01-2011, 12:39 AM   #24
rcbildr
rcbildr's Avatar
Awesome!!! Glad to hear you got it.
My Projects:
1978 Camaro Z28
